Old 07-17-2011, 03:32 PM
famzapata famzapata is offline
WIn 95 "S" PCM 30 amp fuse blow
My 95 3.8 LWndstar blows the "S" PCM 30 amp Fuse every time I try to start, If I disconnect the CCRM doesnīt blow, I change the CCRM and continue blowing the "S" fuse at the engine compartment Fuse box.
I have No idea what could be, please help.
PS: I have the haynes repair manula, so I have read the chasis electrical system (diagram) but I canīt figure out what to do.
Old 07-17-2011, 08:26 PM
danielsatur danielsatur is offline
Re: WIn 95 "S" PCM 30 amp fuse blow
The constant control relay module (CCRM) allows a small signal to give battery to large current device's.
Any device that has a short connected to the CCRM will blow the fuse.
Example-
Check the fuel pressure on the fuel rail, if no pressure the fuel pump could be bad.
You can Isolate fuse's , or connectors going to the CCRM until the fuse doesn't burn.
2000 IG ignition fuse blowing...Please help!!! stanley24538 Metro 5 04-24-2010 09:18 PM
PCM B 20A fuse blows out. DuckSauce Tahoe 5 02-04-2009 06:59 PM
1996 Contour Tranny Elec O/D - Blowing PCM maxi fuse rmschmidt Contour 3 05-06-2007 04:10 PM
90 accord - main 80 amp fuse blowing cartertaylor Accord/TSX/Accord Hybrid 1 10-23-2004 11:18 AM
