Go Back   Automotive Forums Car Chat > MG > MGB
Old 10-05-2011, 05:26 PM
78mgb 78mgb is offline
1978 mgb fuel pump problems
hello i have a 1978 mgb that turns over perfectly, and yes the inertia switch is set correctly, but the carb is not getting any fuel due to the fuel pump not working but we know its a good pump but for some reason it is not getting any juice to it to operate...any suggestions?
Old 10-14-2011, 11:50 AM
alanhauf alanhauf is offline
Re: 1978 mgb fuel pump problems
The fuel pump is feed by the white wire from the ignition switch. You can find a connector on the passenger side fender rear of the fuse block about 6- 12 inches. The main harness meets the rear harness with a bunch of connectors this should be a single bullet connector with white on both sides, of course you need ground from the pump to the body there is a spade lug on the pump and a short wire to the body ground. Here is a link to wiring diagrams for the MGB. http://www.thebriton.com/mgbwiremaster.pdf Look on page 32 I think this will cover your vehicle
89 89 Lebaron 2.5 intermittent fuel pump problem abeduque Lebaron 3 03-04-2011 08:47 PM
1991 Regal Custom- Possible Fuel Pump Problem snickerkisses Regal 1 02-10-2010 10:08 PM
93 suburban fuel pump problem. robert1984 Suburban 2 12-15-2009 02:21 PM
91 corsica 3.1 fuel pump not pumping miecow Corsica 3 05-04-2009 11:39 PM
Fuel pump problem lmattiso Rodeo | Passport | MU 0 04-25-2009 02:08 PM
