Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 03-04-2011, 07:31 PM
abeduque abeduque is offline
89 89 Lebaron 2.5 intermittent fuel pump problem
My 89 Lebaron is giving me intermittent starting problems. The car runs great once I get it started, but I need to turn the ignition switch a few times until I hear the fuel pump go on before the car can turn on. Sometimes I hear it on the first turn and sometimes it takes a dozen. But once I hear the humming of the fuel pump it starts instantly. Until then I just open and close the ignition. Luckily the car almost always eventually turns on. I replaced the fuel pump relay and fuel pressure regulator but there was no change. When the car actually starts I have great fuel pressure.
I used to start it by spraying starter fluid in the intake but since I learned to listen for the hum of the fuel pump this has not been the case.
Can anyone help me solve this mystery? It's driving me crazy!
Old 03-04-2011, 07:56 PM
brcidd's Avatar
brcidd brcidd is offline
Re: 89 89 Lebaron 2.5 intermittent fuel pump problem
Next time it does not come on, have someone Whaaaaap bottom of fuel tank as you turn key on...If pump leaps into action by being bumped, you have a bad fuel pump and it needs replaced. Sooner or later it will leave you stranded- it is worn out.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 03-04-2011, 08:37 PM
I have tried that.
It has not responded. Any other thoughts?
Old 03-04-2011, 08:47 PM
brcidd's Avatar
If your hot and ground to FP all check out.. then it's pretty cut and dry-- replace the FP.
'99 GMC Yukon
'88 E30 has gone thru 2 fuel pumps! coons_7 3 Series 1 06-22-2010 01:16 PM
1999 Jetta GLS 2.0 AEG Fuel system problem Probe '97 - '03 3 04-20-2010 10:24 PM
1991 Regal Custom- Possible Fuel Pump Problem snickerkisses Regal 1 02-10-2010 10:08 PM
93 suburban fuel pump problem. robert1984 Suburban 2 12-15-2009 02:21 PM
Fuel pump problem lmattiso Rodeo | Passport | MU 0 04-25-2009 02:08 PM
Tags
fuel , lebaron , pump , relay
