Old 10-05-2011, 08:45 AM
Crab Spirits Crab Spirits is offline
Fan
I got a 98 cavalier with the 2.2 and the radiator fan refuses to turn on. Doesn't turn on with the A/C either. If you disconnect the the sensor on the coolant bypass pipe, the fan will turn on. Replaced the sensor and it still doesn't work. I'm out of ideas.
Tried searching and found many similar threads but they all had dead ends.
Old 10-05-2011, 09:16 AM
Tech II Tech II is offline
Re: Fan
Is the car overheating? What is your temp gage doing?
May not come on with A/C, if the A/C is not working(does the clutch engage when you turn A/C on?)....
Any codes?
Old 10-05-2011, 10:43 AM
Re: Fan
I'm going to guess his A/C does not work. The car overheats, pegs the gauge and he has to pull over.
94 thunderbird radiator fan/ temp gauge problem frustrated by now Thunderbird 19 08-09-2009 11:05 AM
Fan Clutch Fan Clutch Fan Clutch Gizmo97 TrailBlazer | Trailblazer EXT 5 08-10-2005 07:17 AM
Fan Not Working A/c Fan Works Engine Hot Fan Does Not katrinacat1 Grand Prix 0 02-15-2005 05:50 AM
Holla if you're a Team McLaren fan--Mika H. & David C. Fan!! VR6ERS Formula-One 29 12-20-2001 07:45 AM
