Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Suspension and Drivetrain
Suspension and Drivetrain Discuss suspension, and drivetrain performance modifications here.
Old 10-05-2011, 05:20 AM
DANZIGS DANZIGS is offline
Cut and welded subframe?
Im looking at buying an 83 Z but Im a little hesitant after seeing where the trans crossmember bolts to the frame has been cutout to remove the cross member and rewelded. Apperently the PO removed the tranny and couldnt get the two mounting bolts for the cross member out and decided to cut around the cross member on the driverside frame. The plate and weld looks good along with the rest of the body and undercarriage. Is this going to be an issue in the future? Do they sell replacement c channels? Any help is great.
97 Intrepid 3.3 Sub Frame Bushings and Mounts Gabriel T. Intrepid 1 07-03-2010 05:13 AM
New, free resource for welding and machining terms weldmeister Metal Shaping and Welding 0 10-16-2009 04:28 PM
New, free resource for welding and machining terms weldmeister Metal Shaping and Welding 0 10-16-2009 04:27 PM
my pcm wiring harness got cut and corroded. Xalis Cavalier Problem Diagnosis 4 02-23-2008 01:09 PM
Cutting and using new gaskets DOCTORBILL Metro 6 01-29-2006 12:18 AM
