Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 10-02-2011, 07:32 PM
idontlikechevy81 idontlikechevy81 is offline
bad transmision leak.
hello, i have a 1981 chev silverado 2wd. i just put a new transmission 350 turbo and when i started it. it would spray fluid from backside of torque converter. so i put a new seal in it and then it still did the same thing. oh ya and i put a different torque converter in it. does anyone know what this could possibly be im getting so sick of taking the tranny in and out.thanks
zack
Old 10-02-2011, 08:24 PM
maxwedge maxwedge is offline
A990 racer
Re: bad transmision leak.
Bad/wrong convertor, pump seal bad, not the hub seal but the pump body seal?
Old 10-02-2011, 11:43 PM
trannyman52 trannyman52 is offline
you need to check the bushing behind the seal,,,,may be loose and conacting the seal causing it to leak,,,,,,should check it running ,,,,possible that pump to case o ring seal leaking,,,,,,,or is oil running out from pump seal,,,pump seal will be higher inside case leak will be lower around housing
Old 10-03-2011, 03:18 AM
ggsirg ggsirg is offline
Well my car has been giving me all kinds or problems here recently. My tranmission cooler busted in my radatior.
*Links removed by moderator*
How bad is this news? Radiator leak Donnerpartier Caravan | Voyager 2 06-20-2011 08:00 PM
transmision leak wade623 Aurora 2 06-28-2009 12:53 AM
transmision leak...help jekel5667 Caravan | Voyager 6 01-04-2007 02:17 PM
Bad Coolant Leak!!! k3smostwanted 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 3 08-06-2004 01:31 AM
bad oil leak in 88 t-10 blazer 4.3L please help asap derrick9581 S-10 0 05-25-2003 03:07 AM
