Old 09-30-2011, 06:30 PM
flipjarg's Avatar
flipjarg flipjarg is offline
Is a Torque Wrench a "must have" for Changing Valve Cover Gaskets???
I am about to change my valve cover gaskets this weekend but was told that I may need a torque wrench. The gaskets feel like a light metal, they aren't the paper kind of gaskets. Do you think that I should definitely use a torque wrench or can I just snug it up good but not too tight?
Thanks for the help! :-)
My Vehicle(s):
2001 Subaru Outback H6 3.0L Engine, Automatic Trans.
2000 Olds Alero, 2.4L Engine, Automatic Trans.
Last edited by flipjarg; 09-30-2011 at 06:47 PM. Reason: title didn't have ? marks
Old 10-02-2011, 10:25 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Torque Wrench a "must have" for Changing Valve Cover Gaskets
Always use a torque wrench on valve cover gaskets. An in-lb type. Do you have the bolt torque figures?
Timeslip 08/12/06
AF Community Guidelines
Old 10-06-2011, 07:52 PM
flipjarg's Avatar
I found one to borrow and got that all put back together... thank you for the info. Now I am to the point where I need to get the timing chain and gears back on... http://www.automotiveforums.com/vbul....php?t=1070985
My Vehicle(s):
How to change your lower intake manifold gaskets and valve cover gaskets drdd How-to | Technical Info 20 09-12-2009 12:44 PM
94 3.2 sohc changing valve cover gasket vietrat Trooper | SLX | Bighorn | Wizard 2 09-27-2007 09:50 AM
Need help for replacing valve cover gasket on 96 GC V8 stanleyeye Grand Cherokee | Grand Cherokee SRT8 0 06-25-2007 11:02 PM
How to change valve cover gasket brikat68 Neon | Plymouth Neon 3 05-06-2005 02:41 PM
Tags
cover , gasket , valve
