Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-30-2011, 09:32 AM
Firebird1 Firebird1 is offline
Send a message via AIM to Firebird1
Front frame replacement
Hello, my car has been in serveral accidents over the years and been repaired too. But now that I am do the last hu ra on the car. As I was taking it apart. I thought I saw a crack in the frame. Should I replace the frame or try to have it straighten out or should I just replace it??? And how much does the frame weights???? I don't have any bubbies to help with this task. Can I lift the front end with a engine hoist to remove the frame and set the car/engine on jack stands?
Old 09-30-2011, 03:35 PM
maxwedge maxwedge is offline
A990 racer
Re: Front frame replacement
To answer the issue of repair a body/frame shop needs to look at this. New subframes are available from several sources, of course the engine/trans must be lifted out of the frame and all the suspension, brake and peripheral components transfered, may not be a job for a dyer without the proper supporting equipment and tools.
Possible cause of Rusting front frame freesiagirl Metro 7 08-27-2007 05:03 PM
Help! Engine and front frame Vibration problems KeitaroUrashimaSan Camry/Camry Hybrid/Vista 8 06-07-2007 04:49 PM
Front Frame Width nrtguy C/K 0 05-24-2007 03:43 PM
'95 3.1L-removing rear exh. manifold...lowering drivetrain/front frame assembly? 95oldscutlass Cutlass Series 4 05-03-2006 08:17 PM
