Possible cause of Rusting front frame
Just a thought. I was noticing on my GEO that a little rubber tube was leaking water. It's the A/C drain and it drips right on part of the front frame. Could this be the cause of the terrible rusting frames in sooooo many Metro's???? So, anyway, just to be on the safe side, I'm going to extend that tube, so that it doesn't drain on anything, just the ground....
Re: Possible cause of Rusting front frame
Yes, extending the drain tube is a good idea. You may also want to go to Napa and get a can of Rust Treatment and treat the area, where the rust is. Good luck.
I think everyone should spray as much under their cars as possible with Rust paint. I got some high heat rust paint for stoves actually. My hubby sprayed everything under the car that even looked suspicious. I would hate to lose my little car to a broken frame....
AC Drain hose Mod (1995 Chevy Caprice) Drain tube elbow extended with 3 ft of goodyear hose, and sealed with RTV Sealer. ![]() The drain tube exits out of the bottom of the car and points back to the rear of the car. It's held in place with one of the typical plastic clips you see on wiring harness around the plastic wire loom. ![]() POR-15 Frame Coating. ![]() 3M Pro undercoating on the floor pan (Dark Gray material)
I've got a 96 caprice. Man I love b-body's. Hey, GM, you wouldn't happen to post on the impalassforum would you? Your caprice looks great under there man! Definitely a worth while thing to do - and I'm inspired. I've been meaning to do the a/c drain mod on my caprice, and I think while I'm at it I might set a day aside to treating the underside/frame of my car. The metro is a/c-less, and if it breaks i'll replace it. But the caprice will be staying for a looong time ;-) -MechanicMatt
1996 Caprice 9c1 - Daily Driven Project Car 1993 Geo Metro - Accident 1991 Caprice 9c1 - Destroyed
Link to the entire POR-15 and undercoating project on the SS forum. POR-15 and Undercoating
Oh man. That's just beautiful. Excellent work!
