Old 09-29-2011, 02:01 AM
97explorersport 97explorersport is offline
97 Blazer won't start unless primed
I've changed the fuel pump,spider,fuel regulator,and checked all the relays and fuses. The only way this truck will start is to prime the engine with a shot of gas and then it will start and run great. Shut it off and NO Start. Really pissing me off. I figure it's something simple but it has be baffled. ANY IDEAS???
Old 09-29-2011, 09:29 AM
Tech II Tech II is offline
Re: 97 Blazer won't start unless primed
Have you put a fuel pressure gage on the vehicle? What is the reading....has to be greater than 60 psi to start....
Usually, when it wont start and spraying carb cleaner into the intake, it will, means fuel pressure is marginal(just below 60).....
In the list of parts you replaced, I don't see a fuel filter listed.....that would have been the first thing I replaced....
Old 09-29-2011, 09:35 AM
Ya did the fuel filter also....was a biatch to get off but it was done also....so it needs a minium of 60psi to start? When I had the tank out I did notice a large amount of rust at the pump opening ....would that also cause a pressure drop ??? Tanks(lil pun on words)
Old 09-30-2011, 02:38 PM
chcknugget's Avatar
chcknugget chcknugget is offline
Send a message via AIM to chcknugget
You should check the fuel pressure, it sounds like your new pump is bad...
Old 09-30-2011, 02:45 PM
Scrapper Scrapper is offline
AF Premium User
have you checked spark to see if it's yellow or blue? yellow bad blue good also i would use eather rather than gas. but yeah look see what color of spark your getting?
Old 09-30-2011, 04:02 PM
old_master's Avatar
Advisor/Moderator
The poppet valves, (one in each fuel nozzle) on your 97 CSFI engine require approximately 40psi of fuel pressure to open them and squirt fuel. If fuel pressure is below 40psi, the engine will not run, period! If it's between 40psi and 60psi, it will usually start with a shot of carb cleaner or gasoline, but most likely there will be driveability issues.
Ignition in RUN position, engine off, fuel pump running; Pressure must be 60psi to 66psi and must remain above 55psi for 3 to 5 minutes after the pump shuts off. Post your results.
Don't use starting fluid unless you want bigger problems. Once you see a rocker arm cover get blown clean off an engine, you'll understand
You have to know how it works,
to figure out why it doesn't.
Old 10-01-2011, 11:29 AM
AF Premium User
you would use gas instead of starting fluid? i know what he's talking about just a squirt and it will run. but you been around longer than i have so you must be rite.
Old 10-01-2011, 11:58 AM
DeltaP DeltaP is offline
I do believe he said Carb Cleaner! Not gas, Not ether,(aka starting fluid), unless ya want to drop a valve or blow yer face off!
Old 10-01-2011, 04:59 PM
old_master's Avatar
Advisor/Moderator
Carb cleaner is the safest, easiest, and most convenient. If you put gasoline in a squirt bottle of some sort, or the old style oil can with a pumper, that will work too.
Starting fluid, (ether) is far too volatile and extremely dangerous. One little backfire, or a leaking spark from a plug wire or distributor cap, and you've got an instant fireball in your face. Or, if the engine is cranking, it sucks it in, and the engine backfires, it can blow the oil pan or rocker arm cover clean off with great force! Trust me, seen it happen, not a pretty sight, or sound. A friend of mine working a couple of stalls away from me, had it happen to him. He was damn lucky, all he had was ringing ears for a week.
The Following User Says Thank You to old_master For This Useful Post:
97explorersport (10-01-2011)
Old 10-01-2011, 06:30 PM
Oh NO either for me Just a minor squirt of Petrol from a viscosity tube.........don't need ringing I have 2 EX's that can do that if needed.
Old 11-12-2011, 12:26 PM
g1smith's Avatar
g1smith g1smith is offline
I had a similar issue. Have you checked for injector pulses with a NOID Light? I wasn't getting injector pulses, had to swap the ECM / Computer.
Old 12-01-2011, 12:31 PM
mixin mixin is offline
As crazy as it sounds, try jump starting it. I had a bad battery and didn't know it. Because the battery was bad, the FP would not get enough power to make the psi to start the engine - although it sounded like the starter was cranking fine. If I shot carb cleaner in it or jumpstarted it with another vehicle, it would start fine.
Old 04-01-2015, 10:01 AM
rplabat rplabat is offline
I have the same starting problem.
  1. will start with a boost because it gives you more cranking time to build up fuel pressure.
  2. hitting engine with gas, carburetor cleaner, or starting fluid, ( in that order)
Possible solutions:
  1. possible leak in return fuel line. disturbed by changing a fuel fuel filter or repairing a fuel line. The return line could have a leak letting air onto line.
  2. Bad check valve ( allows fuel to go in one direction, to keep pressure up. ( unfortunately its in the fuel pimp assembly so changing fuel pump corrects that) One person installed another check valve just past the fuel filter and it solved his problem). much cheaper and a lot less work than dropping the fuel tank.
305 TBI Camaro won't start unless primed kutison Engine and Transmission 26 05-24-2016 04:27 PM
95 Chevy S-10 Blazer won't start unless i use starting fluid ktscott1 Blazer 4 10-04-2010 08:18 PM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
1987 CHevy won't start unless primed goer42 C/K 1 10-01-2007 08:59 PM
'90 s10 wont start unless primed, already replaced fuel pump mme43 S-10 4 04-15-2004 04:58 AM
