Old 04-11-2004, 02:38 PM
mme43 mme43 is offline
'90 s10 wont start unless primed, already replaced fuel pump
it was running fine, died one morning. theres a good spark. filter's fine, idle air control valve seems fine. i repleaced the fuel pump. starts and runs when i prime with ether but idles out if left alone.
Old 04-11-2004, 08:56 PM
droptop94 droptop94 is offline
Re: '90 s10 wont start unless primed, already replaced fuel pump
if your getting fuel. try to open the butterfly then start it if this works with out primeing it it could be your tps.
Old 04-12-2004, 08:54 AM
DrtyChvy DrtyChvy is offline
Send a message via Yahoo to DrtyChvy
Hey hey,.. ok,. now this may sound a bit funky,. but you can throw a pony fuel pump up front and put it on a toggle switch. Then just turn the switch on for a few seconds and start errr up. This will prime your fuel line for ya. Then turn the switch off for the pony pump. Did this on my 89 jimmy,.. its quick, its easy
Old 04-14-2004, 11:47 AM
nova racer's Avatar
nova racer nova racer is offline
check for fuel leaks. when you have a cold start problem like that. more than likely there is a fule leak where fuel pressure drops there in no fuel for the injector to squirt.
Old 04-15-2004, 04:58 AM
michelq michelq is offline
did you try to replace fuel pump prime relay
2000 Sonoma Replaced fuel pump ????????? cortervette Bravada 8 12-22-2010 10:42 AM
Won't start unless I pull the fuel pump relay mvvette97 Cavalier Problem Diagnosis 3 08-15-2009 02:03 PM
info needed on replacing fuel pump bri45 Cutlass Series 1 07-12-2009 08:29 PM
1986 se wont start no power to starter, fuel pump, or fp relay NEED HELP!!! connors Fiero 2 10-05-2008 01:34 PM
another wont start, service enging soon flashing, fuel pump fuse buzzing neoflee Venture 5 07-02-2006 05:11 PM
