Old 09-28-2011, 11:53 AM
ivordavies ivordavies is offline
ABS trouble
I have a 99 Grand am with codes ; C1233, C1226 and C1222. Ive tried cleaning the sesors and checking wires. Do I need a new wheel bearing?
1- speed sensor open (C1233)
2- right front or any vibration (C1226)
3-right front or any signal is zero (C1222)
HELP!!!
Old 09-28-2011, 06:09 PM
Tech II Tech II is offline
Re: ABS trouble
We techs have an advantage......called a Tech II....put car up in the air, look at the ABS data, and rotate the wheel....if data says zero, we take a spare wheel hub and rotate it by hand....if we now get a speed reading, the sensor/hub is bad...
If you have a multi meter, you can check the resistance of the sensor and also the A-C out of the sensor when rotating it.....
2000 Ranger 4x4 trouble with ABS engaging tjohn2401 Ranger | Courier 1 01-15-2010 09:05 PM
Need help with ABS trouble light ... Zoom88 B-Series/Bravo/Bounty/Drifter 0 02-06-2006 08:46 AM
96 Sable ABS trouble jstrom Sable 0 12-10-2004 07:49 AM
Odyssey ABS trouble JohnUps Let's get Technical! 1 11-06-2004 11:52 PM
Get ABS Trouble Codes Chris Stewart Bravada 0 06-16-2004 11:21 PM
