Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-05-2004, 10:09 PM
JohnUps JohnUps is offline
Odyssey ABS trouble
The ABS, TCS, & Brake lights are lit up continuously on the dash and the ABS system is inop. Wheels will lock up if tested. Dealer hooked up to computer and codes said there was an error with the right, front ABS/TCS. They said it was probably a relay but would have to troubleshoot to id the exact problem.
I want to try to fix myself. I need help locating the relay(s) that might be faulty. Also, is there any other possible items that could be faulty and produce the same symptoms?
Thanks.
Old 11-06-2004, 11:52 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
Re: Odyssey ABS trouble
the relays for the abs should be under the hood in the fuse box. goto a honda dealer and have them print up the tolerances for the relay(V, Ohms, etc) and test them out.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
