Go Back   Automotive Forums Car Chat > Mercedes-Benz > E-Class
Old 09-27-2011, 11:07 PM
fubard's Avatar
fubard fubard is offline
O2sensor problem
Hello all, I have a 1993 e300 3.2L auto with HFM. and 220KM.The car runs quite well other than I keet getting a code 9 for a faulty O2 sensor. It uses a 4 wire sensor. I replaced the O2 sensor with a compatible O2 sensor not an OEM and I still get the code 9 for a faulty O2 sensor. I attached my meter to it while it's running and I get values between 0.1V -0.8V .It bounces quickly , unlike the old sensor which had little fluctuation and the readings mostly right around 0.4V. I'm considering pulling the connector at the ECU and checking for a wiring fault or corrosion.
Does anyone have any other ideas where to look to fix this?
Autos fixed with help from this forum:
1991 Chev Lumina auto engine hurled
1990 Ford Taurus auto death by high mileage
1995 Ford Taurus auto sold !!!
1989 Ford SHO 5 spd, sold, too finicky
1991 Geo Metro 5spd, SOLD, still ran great
2000 Chev Metro auto sold , mileage was poor
1998 Firefly 3 cyl 53mg!! SOLD I don't commute now
1993 Mercedes 300E sold...looking for a newer one
1999 Mercedes ML320
2000 Taurus my wife's new ride. Bought with only 105K
It's almost a fleet !!
Old 10-20-2011, 10:23 PM
fubard's Avatar
UPDATE O2sensor problem
Well as it turns out there has been no O2 sensor code in over 3 weeks. Initially it threw the code but now it's fine. Maybe it had to dial itself in??!! So far the car is throwing no codes..woot!
1999 Mercedes ML320
The Following User Says Thank You to fubard For This Useful Post:
danielsatur (10-21-2011)
Old 10-21-2011, 08:54 AM
danielsatur danielsatur is offline
Re: O2sensor problem
Did you reset the ECU/PCU, after the H20 sensor replacement?
If not, it had to go through a drive cycle 1st befor clearing itself.
Old 10-23-2011, 01:05 AM
fubard's Avatar
I built the 3 pin LED box to check codes and followed the instructions. After a code is presented hold down the switch for 6 or so seconds and release then do the same for any other code. I checked for any codes and none came up on the LED.
Thanks for the reply..now it's on to fixing a new to me ML320 woo pee
1999 Mercedes ML320
90 deville still cant find the problem chris90deville Deville 3 03-30-2010 02:24 PM
01 Silverado Tranfer Problems kash1235 Silverado 0 04-14-2009 05:44 PM
98 pathy fuel gauge problem akaesha Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 03-28-2009 08:35 PM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
E 150 Starter problem NIck86 Econoline 3 03-12-2009 07:38 AM
