Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Avalanche
Old 09-25-2011, 09:06 PM
bowhuntrrl bowhuntrrl is offline
Steering column knock ???
I just bought a 2005 Avalanche with 95K miles on it. I have a slight knock/vibration in the column when turning tight a very low speeds. I have a fried that told me he heard about some "serious" problem with the columns on some of the Chevs in the 2003-2006 year range. has anyone had this problem before or heard of a serious problem with these???
Old 09-25-2011, 09:40 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Steering column knock ???
No "serious" problems. Steering intermediate shaft noise(if thats what you have)is just annoying, not dangerous. You can replace it or lube it. There is a post on here somewhere about installing a grease zerk into the shaft.
Also, if you disconnect the the shaft from the lower shaft, the one that goes to the gear, you can slide the (i'm trying to make this a clean as possible) upper shaft in and out towards the steering column several times to re-distribute the grease inside the shaft. This will stop the noise for a while, but not a permanent fix.
Old 09-27-2011, 01:12 PM
GMCustomerService's Avatar
GMCustomerService GMCustomerService is offline
I would be happy to look into this for you as well with the last eight of your VIN. Please feel free to contact me privately as well. Thank you in advance.
Tricia, GM Customer Service.
Difference between a '94 and '95 steering column? Steering column guard.. telepunk Trans Sport 1 01-18-2005 01:14 PM
Broken steering column bxdigital Camaro Discussions 2 03-11-2004 07:07 PM
jeep steering column electrical pin-out Savage Hornpoke Wrangler 0 10-08-2002 05:02 PM
Odd noise coming from steering columne Geri Hill Ram Pickup | Ram SRT10 2 12-16-2001 11:10 AM
Can't remove the fifth screw under the steering column.... G20RIDER Cosmetics 1 08-22-2001 08:40 PM
