Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 09-25-2011, 11:02 AM
jckinnick jckinnick is offline
Truck leaking yellow fluid
Lately whenever i come home after washing my truck the next day there is some thing yellowish leaking. Whenever i wash my truck i wash up under the the fender wells and sometimes it could possibly get through the cracks and into the engine a little bit, that is the only thing i can think of that could be causing this.
I just had the gaskets replaced too.
Old 09-28-2011, 08:00 PM
Re: Truck leaking yellow fluid
Pretty sure its not brake fluid.
Old 09-29-2011, 06:04 AM
Flash75 Flash75 is offline
AF - Advisor
Only after washing? What gaskets were replaced and for what reason?
What year truck?
Some antifreeze is yellow. Later trucks have a pink/red antifreeze.
Clifton
Old 10-03-2011, 07:40 PM
What year truck?
Clifton
The valve cover gaskets were changed back last winter. It was leaking about the same just a little bit sometimes when it got real cold.
Old 10-08-2011, 07:02 AM
Got any ideas?
Old 10-24-2011, 02:25 PM
AF - Advisor
If you haven't found the problem. I would look carefully at all coolant fittings and
connections for signs of leaking. The fact it happens only when wash the truck is
confusing. Cannot think of anything that would leak only when washing the vehicle.
I noticed a pop-up stating some Toyoto mechanics were on line waiting on line
to answer questions. You may want to try them. Don't know if there is a charge
for their service.
Good luck.
Clifton
2000 Windstar transmission fluid leak olopezm Windstar 16 09-17-2010 09:51 PM
Brake fluid leak john3mo Lumina 3 11-16-2009 04:28 PM
'94 TS 3800: HUGE coolant leak - and other fluids jarl Trans Sport 23 10-31-2009 08:53 AM
Neverending belt squeak - yellow fluid - a/c leak? searcherrr Windstar 4 12-28-2008 04:34 AM
yellow fluid??? alabama_neon Neon | Plymouth Neon 3 01-15-2005 02:06 AM
