Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 09-25-2011, 02:14 AM
guitarsncars guitarsncars is offline
my 1998 sc2 saturn wnt start... it will crank til the battery goes dead but it doesnt get any fire from the coil backs. i need help...
i have a '98 sc2 and its been sittin in my yard for a while. it started out one day when i got in it, turned the key and then it turned over but wasnt startin. we hooked it to a computer and it showed no bad signal so we bought a new computer for my car and that didnt help either. we changed the coil packs and the crank sensor and still nothin. this is the first car ive ever had trouble fixin and its makin me look like a fool. any sugestions?
Old 12-06-2011, 04:44 PM
Turbotimes2 Turbotimes2 is offline
Re: my 1998 sc2 saturn wnt start... it will crank til the battery goes dead but it doesnt get any fire from the coil backs. i need help...
I have a 2002 sc2 with the same problem. i Removed the spark plugs to find old brown oil all over 3 of the 4. i have replaced all 4 and there is no spark when i turn it over. my best guesses are valve cover gasket or oil gasket is broken, thats what im about to check. also dont let the batter run all the way down, ive had 3 come up with bad cells and had to replace them to continue tryin to figure it out. ill let ya know wat i find under the valve cover
Old 01-21-2012, 10:51 PM
4x4junkie 4x4junkie is offline
a blown fuse to fuel pump, a loose ground wire at fuel pump, or a bad fuel pump relay will prevent starting, and so will low fuel pressure .. pressures must be within the correct specifications, if so consider a short in the circuitry from the MAF or MAPP sensor whichever this specific vehicle has.
4x4Junkie
2012 silverado 1500 ext. cab LT
Z71 4x4 with allstar package
5.3L V8 Flexfuel with 6 speed AT
Onstar / Sirius XM
Factory Tow Package
Electric Brake Controller
Silver Ice Metallic
265/65/18
Wifes Vehicle
2014 Kia Sorento EX AWD
3.3L V6
Toys
2007 Yamaha VStar Silverado
1086cc 45 degree vtwin
Grey and Silver
GPS positioning locator installed
HELP 98 Venture Wont start or crank over Dtompkins Venture 3 12-02-2009 06:50 PM
95 chevy lumina is not getting any fire from spark plugs darin00 Lumina 9 12-22-2008 03:12 PM
battery goes dead overnight from RAP#2 short smelect Suburban 2 10-02-2005 11:50 AM
Cant get Fire from the coils cbass1985 RX-7 12 03-10-2005 06:13 AM
Help code P0153, but I get no readings from any of the o2... the_wraith Explorer | Explorer Sport Trac 0 11-07-2004 08:51 AM
