Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 09-03-2004, 09:58 PM
cbass1985 cbass1985 is offline
Send a message via AIM to cbass1985 Send a message via Yahoo to cbass1985
Angry Cant get Fire from the coils
Hey ya'll im new to this thingy but whatever my problem is that I have a 1987 RX-7 13b rotory. its in great condition. i believe the sparkplugs are good. The motor turns over and everything but i dont get any fire out of the coils. I got the car from a used car salesman/buddy. the ignition coils had been taken off to be used on another car so i bought 2 ""new"" coils from a salvage yard. I hooked them up try to crank it but still get no 'FIRE' from them. Im maily wondering if there could be another problem.... or is it most likely that the coils are bad. If anybody can help i would greatly apreacate it. Thanks HANK
Old 09-04-2004, 10:40 AM
D3rELiC's Avatar
D3rELiC D3rELiC is offline
Re: Cant get Fire from the coils
check the Crank angle sensor, or any bad connection
find someone with a 7 nearby and interchange pieces to see whats going wrong or not
Old 09-05-2004, 11:55 PM
alright man. thanks i'll try the crank angle sensor first. hmmmm since im not very familiar with these wyankels do you know right off hand if the sensor is on the front of the crankshaft or on the back side near the bellhousing. Thanks
Hank
Old 09-06-2004, 08:38 AM
WankelTII WankelTII is offline
crank angle sensor
it looks like a distributer, with no cap, just a flat black plastic cover and one little plug coming out one side of it
Old 02-20-2005, 09:50 AM
lodownlv lodownlv is offline
Send a message via AIM to lodownlv Send a message via Yahoo to lodownlv
im having the same problem im going to recheck the crank angle sensor also is their any volatge on that harnes and if not any voltage on crank angle sensor and coil packs what would be antother place to look fuses? or any required sensors?
Old 02-20-2005, 03:03 PM
Mr. Griff750 Mr. Griff750 is offline
Send a message via AIM to Mr. Griff750 Send a message via MSN to Mr. Griff750 Send a message via Yahoo to Mr. Griff750
Also try regrounding your ignition just for the heck of it
Old 02-20-2005, 07:55 PM
regrounding the ignition where?
Old 02-20-2005, 08:07 PM
D3rELiC's Avatar
Re: Re: Cant get Fire from the coils
try the positive born of the battery
Old 02-20-2005, 11:25 PM
WRC85 WRC85 is offline
i had a similar prob...
i had the same thing happen, but it was on a toyota pickup. I don't know how similar they are, but with that it was the igniter, which is the little metal box that the coil sits on and its basically a computer. It was easy to fix, but the part is incredibly expensive, it listed at 600 bucks
and they'd sell it to me for 400. I ended up getting one from a junkyard for 70. you could check that, but i'm not sure how, we just eliminated everything else that it could have been.
Old 02-21-2005, 06:41 AM
i just found that im not getting power to anything i think its the main relay im going to check later today.
Old 02-22-2005, 03:39 PM
drftk1d's Avatar
drftk1d drftk1d is offline
boost in, apex seals out
Send a message via AIM to drftk1d
check the fuse box underhood.
RX-7 TII
Old 02-22-2005, 06:47 PM
got + 12 THEIR any other sugections what sensors have to be connected in order for the engine to start
Old 03-10-2005, 06:13 AM
problem fixed i found it to be no ground to ecu, fried ecu, fied crank angle sensor, fried traling and leading coils. got it running but keeps stalling. still working on the mazda pain!
