Old 09-24-2011, 09:02 PM
cf1 cf1 is offline
where are the fusses..
i have a 2002 caravan the passenger window wont operate,, where are the fusses located? i found the one panel under the hood next to the battery are there any more with fusses or circut brakers
Old 09-25-2011, 02:35 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: where are the fusses..
A single fuse and circuit breaker pass power to all the windows in the van. You have a single fuse panel - the Integrated Power Module (IPM) under the hood near the battery. Open the door then hold the switch up or down as you slam the door shut. This will sometimes wake up a window motor.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
The Following User Says Thank You to RIP For This Useful Post:
cf1 (09-25-2011)
Old 09-25-2011, 08:20 AM
cf1 cf1 is offline
Red face Re: where are the fusses..
thanks Rip, i know where the panel is under the hood, i thought there was more than one.. i have the door panel off and couldnt get power from the plug at the motor. so if theres no other fuse i need a regulator motor.. thanks
Old 09-26-2011, 02:36 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
If you're not getting power at the motor connector I'd say you either have a bad switch or broken ground or power wire. Was the key switched to "on/run" when you checked for power? Did you try both switches?
cf1 (09-26-2011)
Old 09-26-2011, 03:48 AM
cf1 cf1 is offline
thanks rip, when i checked it i didnt work the switch. i do have power but the regulator is frozen up spayed it with wd40 got it to move a little. now im leting it sit over night and see if it frees up if not a new regulator on ebay is only $42.00 with shipping..thanks
Old 09-26-2011, 04:25 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
cf1 (09-26-2011)
Where are the glass breakage and main unit sensors for the alrm blazzingbrandon 4Runner/GX470 8 12-13-2005 10:23 PM
Can you adjust the seat height in Intrigues? If so, where are the controls? hito Intrigue 2 07-25-2004 06:45 PM
Oh where oh where are the paseo's? Historia General Discussion 0 02-09-2002 11:37 PM
