Old 09-24-2011, 04:30 PM
BMR777 BMR777 is offline
1999 Grand Prix - Can't remove key - shift lock question
Hello,
I'm having a problem with my 1999 Grand Prix where when I turn off the car sometimes I cannot remove the key from the ignition. It will go to the off position, but won't go to the lock position to allow me to remove the key.
I can get the key out by using the shift lock override under the steering column and poking it with a screwdriver.
From looking online, I can see that it could be any number of things, but one solution seems like it may be the most likely, and that is that there might be some wires that unlock the key and these may be going bad causing the problem to occur only intermittently.
My question is, until I can get this fixed, is it ok to use the shift lock override to remove my key in the cases where it gets stuck? Will using this override for the short / possibly long term cause any problems?
Thanks for any help you can provide.
Old 09-24-2011, 05:05 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: 1999 Grand Prix - Can't remove key - shift lock question
You need to make sure the car is going all the way into park.
Old 09-25-2011, 06:37 AM
Tech II Tech II is offline
The problem I usually find, is one or more of the wires going to the BTSI solenoid, in the shifter, has broken due to flexing....usually breaks close to the harness connector....
No harm doing what you are doing.....
Old 09-25-2011, 02:50 PM
Thank you for your reply!
Old 09-25-2011, 05:59 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
I think a bad ignition switch could be the problem. Do you have any electrical problem like the center console lights don't work, the A/C fan works only on the highest setting, anything similar?
Ignition switches are a common problem in those years.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 09-25-2011, 06:30 PM
Oscar.
No signs of an elecrical problem. All of the lights on the console work fine and no problems with the A/C.
Old 09-26-2011, 09:15 PM
olopezm's Avatar
In that case it sounds like you might have a problem with the "key release solenoid"; try searching for those terms and you will see several posts about it. Pay special attention to the threads started by either user tblake or wyllie.
Oscar.
Old 09-27-2011, 05:16 PM
As I said before, you have to temove the shifter handle, and then the top of the console....look at the wire harness to the BTSI....give a slight tug on each wire, can almost guarantee, one or more will break off, if not already broken....
Old 10-05-2011, 09:01 AM
himntnc0917 himntnc0917 is offline
Smile Re: 1999 Grand Prix - Can't remove key - shift lock question
I had the same thing happen randomly, but very frequently for a while. What worked for me: on the underside of the steering column, off to the right slightly, there is a small hole. If you put your finger in, you will feel a small metal pin. Push that towards the front of the car; it doesn't push far. My key rarely gets stuck now, but pushing that little pin works for me every time when it does.
Old 10-11-2011, 06:58 PM
gtpjay gtpjay is offline
I took top off of console & sprayed shifter shaft & everything else that looks like it moves with WD40. It has worked ever since.
Old 11-27-2011, 09:27 AM
steve1954 steve1954 is offline
I have a 1998 Grand Prix and for the last two years have been releasing the key by poking a stick into the hole under the ignition key. The dealer said that i needed to replace the shifter for $450 plus labor. One of the threads said to spray WD40 into the shift handle at the shifter button in the rear. I did this and the problem was solved.
2002 Grand Prix Rear Disk Brake Hub Assembly Removal mtsav8or Grand Prix 1 07-11-2011 10:09 AM
99 Grand Prix acceleration problems MConder Grand Prix 7 12-11-2010 10:08 PM
1990 Grand prix le problem Erik23512 Grand Prix 1 11-05-2010 12:14 PM
1997 grand prix anti-theft system components Konstantin Grand Prix 8 10-13-2010 10:20 AM
98 Grand Prix Wont Start, need help ASAP! atdudonis Grand Prix 3 06-17-2010 08:57 AM
Tags
key , lock , override , shift , stuck
