Old 09-24-2011, 01:19 PM
gserve gserve is offline
PO442 trouble code
I have a 2000 Chevy Blazer 4wd 4 door LT. It keeps throwing code PO442 (x2). I have replaced the gas cap as suggested. What else can I check and where are the components located on the truck? Thanks for any help.
Old 09-24-2011, 08:26 PM
old_master's Avatar
Advisor/Moderator
Re: PO442 trouble code
P0442 is a small leak in the EVAP system, (.030" or smaller). The EVAP system consists of the following: Fuel tank, fuel tank module O ring, fuel tank pressure sensor & seal, purge canister, purge canister vent solenoid, purge control solenoid & seal, fuel tank filler neck & grommet, fuel tank vent line & grommet, fuel filler cap, fuel vapor lines from the tank to the vent solenoid, and up to the purge control solenoid. Those are all things that can and do leak. I probably missed a few items, but that should keep you busy for a while, or you can take it to a shop and have them hook up a smoke tester to find what's leaking.
You have to know how it works,
to figure out why it doesn't.
Old 09-26-2011, 05:00 PM
fiserman fiserman is offline
Make sure you got the right gas cap. My daughters car showed a code and she went to autozone to buy a gas cap.It helped a day or two and the could came back. Then she took it to a mechanic shop who put a tank sensor in it. That helped a day or two then the code came back. Then we took it to a dealer and they put it on the tester and changed the gas cap and it has worked fine sence. We told them we changed the gas cap and they said it was the wrong one. That ordeal cost here about 300.00 dollars because of autozones 7.00 mistake. Good look Fiserman
Old 09-26-2011, 06:10 PM
friesza friesza is offline
well I have had the same code for awhile now...it all started when I paid a shop to change intake manifold gaskets due to leak....they said because it came on a couple weeks after the work they did it couldnt be there fault...still have not been able to track it down and cant afford to get a smoke test done...but I am sure its somewhere under the hood....sometimes it goes off for a few days and then comes back...
trouble codes danielgast46 F Series 6 04-06-2009 07:06 AM
Trouble Code Troubles seethru B-Series/Bravo/Bounty/Drifter 0 06-18-2006 05:16 PM
trouble retrieving trouble codes..HELP!!!! icecreamman33 Grand Prix 0 05-27-2005 09:33 AM
Trouble Code Trouble projectgsr Prelude 0 04-28-2005 05:57 PM
ECM Trouble Code Is it Trouble? Euroguy026 Lumina 1 04-07-2004 11:34 AM
