Old 03-09-2004, 10:51 AM
Euroguy026 Euroguy026 is offline
Lightbulb ECM Trouble Code Is it Trouble?
I got an ECM Trouble Code, somtimes get this one at wierd times, its code 45 Which means Rich Exhaust, I dont think the oxygen sensor is old but might it be time for replacment, i just had an inspection and the first time it didnt pass the emission but a little margain. I know that it either has to be the O2 Sensor or My Temp Sensor because the sensor to the Temp gauge inside the car is not working.
93 Chevy Lumina Euro 3.1 V6
4T60-E Tranny
Beware My Euro May Be After U!
www.cardomain.com/id/euroguy026
The LUMINATOR LIVES On
Intimidator (#3 Nascar) + Lumina = Luminator
Old 04-07-2004, 11:34 AM
toivo toivo is offline
Re: ECM Trouble Code Is it Trouble?
check your temp sensor connector and see if its loose, then measure voltage at the sensor, should be 5 volts. if you have voltage then it most likely is your sensor but i think you have 2 temp. sensors, make sure you have the right one.
In need of major help. KyleMan Maintenance 2 01-11-2010 12:19 PM
trouble codes danielgast46 F Series 6 04-06-2009 07:06 AM
Trouble Code Troubles seethru B-Series/Bravo/Bounty/Drifter 0 06-18-2006 05:16 PM
trouble retrieving trouble codes..HELP!!!! icecreamman33 Grand Prix 0 05-27-2005 09:33 AM
Trouble Code Trouble projectgsr Prelude 0 04-28-2005 05:57 PM
