Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 09-23-2011, 06:42 PM
djtroz djtroz is offline
LF Power Window Won't Go Down
The other three windows work fine. The driver's side front will not go down. I tried replacing the switch and nothing. I removed the panel and put my hand over the motor. The motor (without pressing the switches) was very warm. While holding the bottom of the motor, I pressed up on the switch and could feel the motor engaging but being the windows was all the way up, it couldn't go any farther. I then repeatedly pressed down and didn't feel or hear anything.
Any ideas? My neighbor said he's seen a defect in Lincolns where a plastic gear strips out. I was considering pulling the motor out and checking it but before I did, wondering if I can test any of the wiring first... just don't know which...
Old 09-26-2011, 10:31 AM
65comet's Avatar
65comet 65comet is offline
Re: LF Power Window Won't Go Down
My 05 had a kink in the cable that bound it up inside the mechanism for the regulator that later led to the cable breaking. Unbolt the motor from the mechanism and see if it goes in both directions. The cables for the regulators are notorious for being bad. I made sure I went with a different brand from stock when I replaced my regulator. Many people would have the new from Ford break within a couple months of installation.
Power Windows don't work joenobodyyet '96-'00 Civic 2 03-29-2012 07:07 PM
'95 Passat FL power window problem frescoraja '93 - '96 1 06-19-2010 01:44 PM
Power Windows Elec Prob. Please help!! dlane85 Corsica 1 07-29-2009 10:37 PM
`99 Power Window Problem.. beadlingi Prism 0 04-27-2009 06:13 PM
98 power window express down problem fliplover Monte Carlo 1 04-03-2009 11:48 AM
