Go Back   Automotive Forums Car Chat > Fabrication & Tools > Metal Shaping and Welding
Metal Shaping and Welding Discuss metal shaping and welding techniques. Share your projects or tips and tricks.
Old 09-21-2011, 11:09 AM
Tony Silva's Avatar
Tony Silva Tony Silva is offline
V8 Chevy p/s pump
Can anybody point me in the right direction for some info on fabbing some power steering pump brackets for small block Chevys?
I would like to use the bolt hole heads in the small block chevy engine design which will place the pump up high as well as a set of brackets for the early chevy non-bolt-holes in the heads which will place the pump down low.
And for all you 'flammers' out there...."No, I don't plan on installing 2 steering pumps on one engine.
Thanx in advance.
Old 12-01-2011, 09:38 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Re: V8 Chevy p/s pump
Thanx in advance.
I know this thread is slightly old but if you are still in need of said brackets , many vendors ( Jegs , Summit , etc. ) offer brackets for your application . Also look at www.alangrovecomponents.com as they offer custom brackets . Good luck !
" Sometimes I grow so tired "
'92 Chevy Z71 Fuel Pump costajoe C/K 1 12-29-2004 04:34 PM
Need a cheap 2000 Chevy blazer fuel pump gsapp24 Blazer 1 08-30-2004 12:59 AM
99 chevy z71 water pump prob eracerX C/K 1 08-24-2004 11:12 AM
1996 chevy blazer fuel pump clark123 Blazer 0 07-15-2004 08:07 PM
2001 Chevy Lumina Air Pump? tblake Lumina 2 07-09-2004 11:27 PM
