Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-20-2011, 05:53 PM
Cavalier9696's Avatar
Cavalier9696 Cavalier9696 is offline
Send a message via Yahoo to Cavalier9696
Turbo Tranny
I have posted about a tranny problem and the problem fixed. But now it is messing up again. Turns out the stock 420a tranny cannot handle a turbo. It is destroying the barrings on my input shaft (from what the machanic says) He said the clutch plate is fine.
Is there at all a tranny made for a 420a with turbo? IM getting desperate. Car has been sitting in the shop for almost 2 months. I went to a site called http://www.engineandtransmissionworld.com and when I put that I have a 1995 Mit Eclipse, it turns up with a MT-FWD NT and Turbo. But I never thought they made a turbo tranny for a 420a. But from what the site turns up they do. I don't want to spend $800 until I know it is the right one. Thanks.
1995 Eclipse RS 5psi
Garret T3/T4 Turbo, Procharger FMU, TurboXS BOV, OBX Evolution 35mm External WG, HKS Intercooler, Apexi DP, Apexi exhaust.
Old 09-20-2011, 08:18 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Turbo Tranny
Donno if you realize this or not but there was a FWD turbo... It was the GST... It used the 4g63 motor... That is the one in reference...
There have been several members here that turbocharged their 420a motors and have had no problems with their tranny. Maybe a few clutch issues but I never heard of anything major with the tranny. Are you sure yours just didn't have issues before all this was done to it? Proper maintenance? Gotta explore all the possibilities so ya don't have another tranny go bad on you.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 09-20-2011, 09:52 PM
Re: Turbo Tranny
When I bought the car it had a tranny problem. I bought a new clutch for it. About 4 months later it started slipping and 5th gear was popping out to were I had to old it in gear. The guy that is working on it said he is going to replace the input shaft and barrings cause he said that is whats causing the 5th gear to pop. Hoping after he fixes that, I will be ok cause when the tranny was fixed about 4 or 5 months ago the input shaft wasn't replaced.
One more question. Can a 4g63 bolt up to a 95rs? And the wiring match? Sorry if I asked that question before.
Old 09-21-2011, 07:08 AM
Re: Turbo Tranny
No, a 4g63 motor cannot drop into an rs and bolt right up and match up with wiring. The two motors are completely opposite of each other in the engine bays.
I would say you need to get all the problems within your tranny ironed out first. Your motor being turbocharged will not cause the problems your experiencing. I believe your tranny may have been abused by the prior owner and that is causing all your current tranny woes. I went thru the same thing with my tranny from the previous owner when I first got it.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 09-23-2011, 09:30 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Turbo Tranny
Just put another stock tranny in it. They do make built trannies for the 420a, but I forgot who makes them. My tranny is bone stock with almost 150k on it and its fine with almost 400bhp going threw it. Never had a single issue
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-23-2011, 07:32 PM
ned032002's Avatar
ned032002 ned032002 is offline
Re: Turbo Tranny
^ With that being said, I would look to blame other parts before blaming the tranny. my .02
Old 09-26-2011, 09:48 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Turbo Tranny
Same here. Never had a trans problem after my rebuild (5th was popping out). Rebuild with a good clutch and you're set.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Turbo tranny Tafnar Pick-Up 0 06-12-2004 05:00 PM
Turbo tranny Tafnar 4Runner/GX470 0 06-12-2004 04:58 PM
Looking for a turbo tranny sensor hodunwun Off-Topic 0 04-04-2004 12:04 AM
What is the difference between turbo tranny and non turbo tranny???? supereclipse96 Off-Topic 2 01-10-2004 03:35 PM
1990 Turbo Tranny same as NA Transmission?? FlexinTwinZ 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 1 06-11-2003 01:43 PM
