Old 09-19-2011, 06:03 PM
327chevy 327chevy is offline
Power window issue 99 Silverado
Can someone tell me if the power window on the passenger door will work via the drivers door button without the passenger window button plugged in?I hope I'm explaining this enough but here's the scenerio I have right now,I am missing the passenger door inner panel and window button,it's at a friends,and the window will not go up or down with the drivers side button.I'm not sure if something is screwed up or if this is normal to need both buttons plugged in for the drivers side controls to work.
Old 09-19-2011, 06:32 PM
gmtech79's Avatar
gmtech79 gmtech79 is offline
U need both switches connected. When using the driver switch power goes from that switch through the pass switch and to the window motor.
If u give me some time to get some things done I can look at a schematic and tell u which wires to jumper to roll the window up.
Sent from my Droid X. Typos probable.
ASE Master
ASE Advanced Engine performance
GM World Class Technician
1978 Pontiac Trans Am
1984 Monte Carlo SS
1991 GMC C1500
2002 Pontiac Grand Prix
Old 09-19-2011, 07:12 PM
gmtech79's Avatar
Re: Power window issue 99 Silverado
If you have jumper wires connect the dark blue wire to the largest black wire and then connect the brown wire to orange wire. This is to be done at the passenger window switch connector. With the key in run the window should go up for you.
ASE Master
1984 Monte Carlo SS
1991 GMC C1500
Power Windows don't work joenobodyyet '96-'00 Civic 2 03-29-2012 07:07 PM
'95 Passat FL power window problem frescoraja '93 - '96 1 06-19-2010 01:44 PM
Power Windows Elec Prob. Please help!! dlane85 Corsica 1 07-29-2009 10:37 PM
`99 Power Window Problem.. beadlingi Prism 0 04-27-2009 06:13 PM
98 power window express down problem fliplover Monte Carlo 1 04-03-2009 11:48 AM
