2011 Fusion Fog Lamp wiring schematics
I have a 2011 fusion SE and I am looking for the wireing schematics for the fog lights. I want to know what wire dose what? and if it is + or - switching. any ideas?
Re: 2011 Fusion Fog Lamp wiring schematics
I'm not sure if you've found an answer yet, but if not, I can provide you with the wiring diagram. Are you referring to the wiring from the switch to the relay, or from the relay to the lights? The switch, when on, provides ground to the Smart Junction Box (SJB) on the Gray/Violet wire (Pin 5 of main light switch, pin 49 at SJB). There is some logic in the SJB which then triggers the Fog Light Relay internal to the SJB. The relay provides power to both fog lights on the Brown/Yellow wire from pin 3 of the SJB connector. The other wire at each fog light (Black/Gray for right, Black/Yellow for left) is tied to ground.
-Rod |
