Go Back   Automotive Forums Car Chat > Jaguar > S-Type
Old 09-17-2011, 05:42 PM
danielsatur danielsatur is offline
2000 S Type Jaguar with Engine damage.
2000 S type Platinum silver 4.0/150k miles on the clock.
Body - 9
Tires - 1
Interior - 7
Engine - 2
I bought it the other day for $600, and haven't decided to fix or part it.
Compression test's on bank 1.
60lbs - 4
00lbs - 3
60lbs - 2
00lbs - 1
Compression test's on bank 2.
30lbs - 8
30lbs - 7
30lbs - 6
00lbs - 5
Firing order -
1,5,4,2
6,3,7,8
Cylinders 1-8
Tran
4 8
3 7
2 6
1 5
Fan
* It looks like the cam to cam & cam to crank timing went bad on this V8 DOHC.
parts list - fel-pro
stretch head bolts - $88.00
valve cover and spark plug boss seals - $60.00
new valve stem seals
head gaskets - $60
intake gasket
primary/secondary cam chain + tensioners $212.00
intake/exhaust valves? 1 pair = $40.00
Notes:
Kelly Blue book price for a 2000 S TYPE 4.0 in good cond is $4100,
1) The secondary cam chain and tensioner is gone on bank 1.
2) The secondary cam chain is good, but the tensioner is bad on bank 2.
3) Timing chain cover removal in-progress.
4) Both the alternator + power steering pump, and mounts need to be taken off.
see http://www.jagservice.net/jaguar_v8_...tensioners.htm , also
http://www.partsgeek.com
Tightening torques -
Heads - 23Nm /17 ft pounds
Intake - 21Nm/15 ft pounds
Cam- - 10Nm/7.38 ft pounds
Tensioner -12Nm/8.85 ft pounds
Front engine cover - 12Nm/8.85 ft pounds
Cop cover - 5Nm/
Old 04-20-2012, 04:43 PM
Re: 2000 S Type Jaguar with Engine damage.
Found a used 4.0 V8 @ LKQX for $200 .
The compression is good, it only needs new valve cover gaskets and secondary cam chain tensioners
Frankfurt 2011: Jaguar Unveils C-X16 Concept AF News Desk General Discussion 0 09-17-2011 09:40 AM
What to do with a damaged 2001 Jetta? ambomo '97 - '03 3 12-21-2009 08:47 PM
How much is my 99 taurus with a damaged engine worth KillaKaze024 General Discussion 1 11-19-2007 07:08 PM
Opinion needed. 2000 civic SI with Integra Type R motor. mellowboy '88 - '91 Civic | CRX | Wagon | Shuttlee 34 08-21-2006 03:27 PM
