Old 09-15-2011, 08:56 PM
terryshrout terryshrout is offline
AF Frequent Flyer
Radio Whine In '04 GP
Here we are again. My daughter's '04 GP GT, 3.8L, with 92,000 mi. has an occasional whine that seems to come through the front speakers. Funny thing is that you still hear the noise when the radio is turned off. The noise is intermitent (hear it two or three times a week). The noise would seem to intensify based on actuating the throttle (don't hear it when coasting, gets louder as you increase throttle position). Usually clears itself when you shut the car off. My daughter asked a dealer mechanic about the problem and without looking at the car he thought it might be the radio amplifier going out (a $350 item). Just looking for some ideas from anyone out there before blindly replacing parts. Thanks in advance for the advice..........again.
Old 09-15-2011, 10:56 PM
deb0704us deb0704us is offline
Send a message via AIM to deb0704us Send a message via Yahoo to deb0704us
Re: Radio Whine In '04 GP
Sounds like a bad ground wire. Wish I'd know that when I had my '98 Grand Prix with the whine. Please see this thread.
http://www.automotiveforums.com/vbul...ht=radio+noise
Good luck!
My New Vehicle:
2008 Grand Prix GXP
Crimson Red ~ 4 Door
8 Cylinders All Mine
It's Loaded!
I'm Lovin' It!
Former Vehicle Totaled in Crash:
1998 Grand Prix GT
Bright Red ~ 4 Door
Old 09-17-2011, 09:05 PM
AF Frequent Flyer
Thanks for the suggestion. I'll check that out and let everyone know if that takes care of the situation. I appreciate you taking the time to help.
Old 10-02-2011, 10:16 PM
AF Frequent Flyer
deb0704us, finally was able to get daughter's car back and work on it again. Per your suggestion checked the radio ground, it seemed OK. What I did find was corrosion on the negative battery post. Took both battery cables off used chemical battery cleaner and wire brushed cable ends and battery posts. So far so good, speaker whine is gone. Really appreciate the tips. That's what I like, a cheap fix that I can actually do correctly. Seems these instances are few and far between. Thanks for the help. She should be a happier camper now.
Old 10-03-2011, 07:56 AM
Tech II Tech II is offline
If the noise comes back, check the radio ground module bolt, located at rear of headliner, in center about 4" in.....have to drop liner to access....
Old 10-03-2011, 08:00 PM
AF Frequent Flyer
Thanks again to all who help. Your assistance is most appreciated. I'll keep that last tip in mind if this doesn't work. Hopefully I won't need it but I never hurts to have a little ammo in reserve. If the noise does come back I'll keep everyone posted.
RCA cords in amp create loud whine fossez Car Audio 3 04-13-2011 07:57 PM
1986 olds 98 regency fuel pump whines in idle?? cdd109 Ninety Eight 4 12-28-2010 07:32 PM
Whiring & Whining sound on my 2003 Envoy 170KM washind Envoy 7 03-31-2010 08:25 AM
1995-200? Lumina (GM) radio LED conversion saxonmor Car Audio 0 03-01-2009 09:59 PM
Trannie Whine/'04 Maxx wpbharry Malibu 2 03-27-2005 11:37 AM
