Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 12-27-2010, 07:46 PM
cdd109 cdd109 is offline
Question 1986 olds 98 regency fuel pump whines in idle??
1986 olds 98 regency brougham elite
loud whine from gas tank / FP area when car is idling, put when you accelerate the whine completely disappears until you take your foot off the pedal. Have read that it could be because a of cheap fuel pump (recently replaced - didn't spend more than $150 for the assembly (FP/Tank)). I replaced the fuel filter.
Also heard it could be a clogged CAT but the exhaust breaths great, miles are 48K (though it is the original 86 CAT installed). But really the sound is almost certainly coming from inside the tank. loudest is near filler neck.
Any ideas greatly appreciated???
http://clicknbank.us
Old 12-28-2010, 08:06 AM
maxwedge maxwedge is offline
A990 racer
Re: 1986 olds 98 regency fuel pump whines in idle??
Cheap fuel pump usually, but how about the chassis filter and/or tank strainer, were they both replaced?
Old 12-28-2010, 04:18 PM
That's a good question. That is the one job I didn't do myself, and the first I had done. I have wondered about the Fuel Pump Strainer myself...reason being because I found both the old AND an new one in the trunk several weeks later! That could mean they forgot to put it on, or they had 2 new ones.?. (Of course they say they put a new one on). Anyway, first I am hearing about a chasis filter, and not sure about the state of the strainer.
Old 12-28-2010, 06:39 PM
A990 racer
If the regular filter in line in the front of the tank is resrticted it will cause the pump to be noisey, that is replaced on a 30k interval as it is.
Old 12-28-2010, 07:32 PM
I will definitely look into that and change it. Thanks very much for your advice!
2000 Sonoma Replaced fuel pump ????????? cortervette Bravada 8 12-22-2010 10:42 AM
91 corsica 3.1 fuel pump not pumping miecow Corsica 3 05-04-2009 11:39 PM
Fuel pump problem lmattiso Rodeo | Passport | MU 0 04-25-2009 02:08 PM
Help with Fuel Pump Resister Relay bbaker1985 Grand Prix 1 03-28-2009 09:14 PM
gtp fuel pump? finkk Grand Prix 9 03-13-2009 08:04 AM
Tags
1986 , fuelpump , idling , whining
