Go Back   Automotive Forums Car Chat > Mazda > 626/Capella/Capella Wagon
Old 09-14-2011, 12:42 AM
DaddyMcClees DaddyMcClees is offline
turn key on/off mutliple times before it starts
I have a 2000 626 and sometimes (not always) I have to turn the key on/off multiple times before it starts? I usually do it fast until I hear it starting then hold it.... Is this a telltale sign of a specific problem or could it be a few different things?
Old 09-14-2011, 05:17 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: turn key on/off mutliple times before it starts
G'day, welcome to the forums.
Sounds a lot like the ignition switch has failed.
If you hear a clicking noise from the engine when you turn the key however, it will be the starter motor solenoid
Old 12-24-2011, 02:58 PM
borninabarn borninabarn is offline
MY Mothers is doing the same thing! I have replaced the coil,Ignition switch as posts I have written here about the problem.After you turn the key back and forth many times it with SOMETIME START.Thats why I replaced the Ignition switch that is real easy to replace but that wasnt the problem.When I hear the fuel pump buzzing it will start if not it wont.Let me know if you get yours figured out please.
Turn key and nothing. no dash lights or response from the key turn at all. grrrtyson Cherokee 3 04-26-2010 12:12 PM
95 Chevy cranks along time before starting BHolm Silverado 10 01-25-2008 02:46 PM
Hard to start. Have to turn the motor over three times to start. gschretter Silverado 20 07-07-2007 09:58 PM
Turning Over 30 Times Before Starting steeda763 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 6 03-02-2006 09:20 PM
turned the key over, took 9 times to start... Green Machine 95 Aurora 18 10-07-2004 06:13 PM
