Old 09-14-2011, 12:00 AM
cf1 cf1 is offline
window wont operate
picked up a 2002 caravan passenger window wont function.. fusses look good any help.. thanks
Old 09-22-2011, 05:36 PM
hammer2 hammer2 is offline
Re: window wont operate
tried it from both passenger and driver switches already, right? would start by taking off the door panel. probably couple screws, then the rest is just pushed in place. find the regulator motor and pull the wire connector off of it. then check for power at the connector-need tester, put a lead in each of the sockets of the connector (obviously NOT the side on the motor but the harness coming to it) then flip the switch . I am pretty sure you should have +12V for one direction and -12V for the other. if you do, then it is the motor. unfortunately, it may not be replaceable. you have to buy whole regulator on my 2003 grand caravan (that is why my window hasn't worked for years! it is very expensive). you can try taking apart the motor, cleaning it, and putting it back together. on my car, I did this and adjusted the tension on it and has worked for 8 years! tried on van but only worked for week or so. can't adjust tension on it.
if you don't have power at connector make sure you check other switch too. if neither give you power, then you have to test switch and have to make sure you have power coming into the switch. need little experience with circuits to do this cause there are probably all kinds of wires and without wiring diagram it is too hard to try to explain how to do it.
The Following User Says Thank You to hammer2 For This Useful Post:
cf1 (09-22-2011)
Old 09-22-2011, 09:24 PM
cf1 cf1 is offline
ok thanks i will check the switch, and motor..
Old 09-24-2011, 08:57 PM
cf1 cf1 is offline
i pulled the panel off the door and unhooked the plug that gos onto the motor, there is no power from the harness that plugs into the motor.. i have no owners manual on this van and the only fuses i find are under the hood next to the battery,, are there any other place there is fusses? thank
Fan wont blow and windows wont roll down. woodyxjs LHS 1 06-26-2011 04:11 PM
Driver side window operation and washers are out Moonzuk Sierra 0 06-16-2009 09:25 AM
Passenger window non operational allwood Eclipse 2000+ 16 12-19-2005 10:38 PM
97 Trans Sport Rear Power Window Intermittent Operation BarryH Trans Sport 2 01-10-2005 06:23 PM
Tinted my windows, windows wont work.... Green Machine 95 Aurora 3 10-03-2003 02:37 PM
