Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 09-13-2011, 09:16 PM
tannerr52's Avatar
tannerr52 tannerr52 is offline
Transmission issues
Hello Everyone.
My car has always done this since ive had it. When i go to shift into rev. from park, i get a slight jolt. It also does from park to drive and so on. Also, when im driving and the transmissionshifts, i also get a little bit of lag. I really hope my transmission isnt slipping. It is using a little bit of fluid but im not 100 percent on that. Would doing a flush/ filter replacement help? i really know nothing about stuff like transmissions, so on.
Thanks,
Tanner
1990 Pontiac Bonneville- 200k -3.8L SOLD Bye Bonnie I'll miss you.
1998 Jeep Grand Cherokee Laredo- 5.2L V8 - 140k TOTALED You were an ok Jeep...
Current ride:
1996 Jeep Grand Cherokee Laredo- 4.0L L6 - 110k
Old 09-14-2011, 02:22 PM
tannerr52's Avatar
Re: Transmission issues
anybody??!
Current ride:
Old 09-14-2011, 02:36 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Originally Posted by tannerr52 View Post
anybody??!
G'day, the wonders of the internet is things don't always happen right away
It's quite normal for an older automatic to have some lag and jolts when selecting drive.
They don't "use" fluid either, there is nothing going on inside that can consume it.
But, they can leak.
If it's leaking and the level has gotten low, then it will make any jolts and delays etc worse.
Old 09-14-2011, 02:41 PM
tannerr52's Avatar
Haha ok ok. That is true. But such a simple question, and that ive gotten quicker responses before. :P
Anyway, yeah i meant a leak instead of being used. But i cant really tell if its a leak. Do you think that new fluid/filter/seal would help it? (Ive heard that it can make it worse.)
Thanks,
Tanner
Current ride:
Old 09-15-2011, 01:29 AM
trannyman52 trannyman52 is offline
A flush is a waste of money,,,,,fluid & filter change a good idea,,,,the reason for a flush is to exchange fluid without disturbing filter,,,there is a risk of allowing contaminents into system when removing filter,,,then the finger pointing starts,,,,YOU SCREWED MY TRANSMISSION UP !!!!!!! when the problem was already there!!!!! the lag or delay can be caused by converter drain down from sitting over night,,,,to filter with restriction,,,could be a problem with coverter but normally they work,,,or they don't....the jolt,,,,hmmmmm.....the soft transition,,,there is a vacume modulator on front of trans,,,this sets,,,adjusts line pressure of transmission,,,looks at vacume rise and fall and adjusts accordingly,,,may want to replace this,,,whatch what you are replacing with,,,several design variations of internal valve ,,,,,must replace with same internal valve train,,,modulator may not look the same but the valve train MUST be the same that came out,,,also check hoses ,,tubing supplying vacume to modulator.......overfill transmission by at least 1 quart,,it needs it!!!!
Old 09-15-2011, 01:12 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
You're better off draining and filling 2 to 3 times to exchange the old fluid for new. Drain, replace the filter and refill. Run a few days, then drain & refill again (no filter replacement). Run a few more days, then drain & fill a third time. Yes, it is time-consuming and somwhat wasteful, but the cost is on par with flushing and is much gentler in removing any build-up.
Flushes generally do more harm than good, especially for transmissions that have been forgotten/neglected. Varnish and other debris can become dislodged by the process and then redeposited in the valve body where it can screw up the valving, passageways, etc.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 09-18-2011, 11:25 AM
tannerr52's Avatar
Well i was just going to change the fluid and filter. no flushes. I think flushes are pretty bad on yout tranny anyway...
Current ride:
Old 09-21-2011, 10:49 PM
tannerr52's Avatar
I'm just gonna try a fluid/filter change this weekend. its cheap and it might help. Im prolly not going to flush, though.
Current ride:
Old 10-24-2011, 07:39 PM
tannerr52's Avatar
UPDATE
Man its been forever since iven been on here.
Anyway, i did do the change of the fluid, and filter replace. it actually helped out quite a bit, but not a *huge* difference..
Current ride:
Old 10-27-2011, 02:08 PM
bsansa bsansa is offline
I've always heard bad things about overfilling a transmission. Could adding a Lucas Trans Tune/Fix be any help?
Old 10-27-2011, 06:32 PM
Tech II Tech II is offline
Have you checked engine/transmission mounts?
98 Transmission shifting issue zawillia Windstar 4 05-02-2010 02:21 PM
94 prizm transmission issues theginchico Engineering/ Technical 3 04-12-2010 07:17 PM
1989 grand marquis transmission issues Thepinkmommy Grand Marquis 2 04-03-2010 10:26 PM
transmission issues. 91 buick regal 3.8 bac512 Regal 0 04-25-2009 11:58 AM
Transmission Issues hoowahman Park Avenue 1 11-19-2002 03:30 PM
Tags
jolt , lag , shift , slip , transmission
