Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 04-03-2010, 01:16 PM
Thepinkmommy Thepinkmommy is offline
Question 1989 grand marquis transmission issues
I was wondering if anyone can tell me where the cap is to add transmission fluid to my car. i check the levels and need to add some but can't figure out where? Please Help!
Old 04-03-2010, 06:41 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 1989 grand marquis transmission issues
There is no cap. Where you checked the level of the fluid is where you add the transmission fluid. Did you check the fluid when it was running and the engine warm, transmission in park? You will need a funnel to put the fluid in.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 04-03-2010, 10:26 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
And when way2old says engine warm, he really means ATF up to normal operating temperature (about 150-180F). I find that in the cold winter weather (below 40F), it can require up to 25 minutes of city driving. Summer requires about 15 minutes of city driving.
And remember to run the transmission through all the gears prior to checking the dipstick,including reverse.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Tags
1989 , grand , marquis , transmission
