Old 09-13-2011, 02:59 PM
Wags391 Wags391 is offline
10-year Owner
1992 Blazer Multifunction Switch
Has anyone gotten into the multifunction switch of a 92 blazer? My wipers are sporadic and the front washer pump won't work. Voltage is only only 10 volts when tested and the pump works with a 12 volt jumper. I can't see how to get to the switch to check it out though.
Old 09-15-2011, 01:45 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 1992 Blazer Multifunction Switch
Test switch wring under dash where they come out of steerig column at the wiring plug in.
You will need a volt/ohm meter.
Some of the switch switching is in ohm's and some voltage and do not forget to test ground.
Good wiring diagrams helps to find which wire is what there.
On sporadic wipers.
There is a lot of problems and some recalls on the wiper circuit board if you have the intermitent wipers.
MT
99 blazer multifunction switch gioman Problem Diagnosis 1 09-30-2007 07:36 PM
Multifunction Switch '95 Blazer BlazerLS Blazer 4 11-22-2004 02:47 PM
Multifunction switch b83 Sierra 0 12-27-2003 11:34 AM
Multifunction switch kekul Explorer | Explorer Sport Trac 0 12-05-2003 06:38 AM
