Old 09-13-2011, 04:49 AM
chubcobear's Avatar
chubcobear chubcobear is offline
Thanks HotZ28 for the tip.....
In July 09 you recommended Goodyear Gatorback belt for smith1000 when he had a "chirping" problem with his serpentine belt. I tried it for my same type problem and it worked. This problem started after I replaced a blown a/c compressor with a Dorman Idler pulley. I think there must have been a slight mis-allignment of the pulleys that helped cause the "chirp". Thanks for the tip.
Old 09-13-2011, 09:11 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Thanks HotZ28 for the tip.....
Thanks for the feedback, and good to here you had positive results. Metal pulleys tend to chirp more than plastic, especially if there is a slight misalignment. If you have any metal idler pulleys, I would suggest replacing them with plastic. This is the reason plastic was installed at the factory.
Old 09-13-2011, 01:20 PM
chubcobear's Avatar
Actually, HotZ28, I had already replaced the spring-loaded idler pulley in an effort to solve the chirp problem. When I had the belt off I checked all the other pulleys, too. I never thot to replace the nearly new belt until I read your old post.
Of course, Gatorback belt solved it.
Cars for the Cure 2009 Pictures Pastapuck Car Shows 0 02-11-2009 10:45 PM
Thank god for the factory alarm Biggsj84 Camaro Discussions 4 01-27-2005 02:29 PM
TURBO PIC (more to come its late long weekend) Thanks GTA FOR THE HELP Cjz89civic '88 - '91 Civic | CRX | Wagon | Shuttlee 7 10-04-2004 08:23 PM
Thanks Menu for the good website . . . raven1822 Murciélago (Murcielago) 0 02-10-2003 09:50 AM
Thanks Guys for The help Crxce '88 - '91 Civic | CRX | Wagon | Shuttlee 8 02-06-2003 12:52 PM
