Old 09-12-2011, 10:17 PM
wkumale wkumale is offline
MIDDLE VENTS NOT WORKING... While Outer vents do????
I have a 97 cherokee 4wd 4.0 automative with 200K
I just got this and dont know the history. The ac works great on defrost. It does not blow out of the middle vents... It does blow out of the outer vents by the doors. It even sounds like it wants to work in the middle vents. It sounds like maybe something is blocking it.... i dunno... Is there a "flap" that needs to open or close or something? I am not sure what to do.. I was thinking it may be a vacuum leak but why would the outter ones work if it had a leak.... ANY help would be great.
Should I put the dash? If so how hard is that? I looked for instructions on that but found none for a 97-01 model
Thanks
TJ
TJ
1994 Ford Ranger 4x4 4.0
Old 09-18-2011, 12:50 PM
Saudade's Avatar
Saudade Saudade is offline
Re: MIDDLE VENTS NOT WORKING... While Outer vents do????
You most likely have a vacuum leak. The "flapper" doors are vacuum operated. When they are low or have no vacuum, the default to the defrost vents.
There is a plastic bottle (vacuum reservoir) behind the front bumper, passenger side. There are also plastic vacuum lines that run under the battery. Check them for breakage. Follow the lines to the firewall.
Dad's taxi:
'88 XJ - 190K and going strong.
K&N, Ford Injectors, No other mods
2000 Windstar Air vents not working right olopezm Windstar 11 08-04-2010 09:09 PM
heat...A/C vents not working??vacuum? penguins_chic66 Trans Sport 6 09-23-2004 03:22 PM
1988 XJ heating/AC vents not working pdlee Cherokee 10 07-15-2004 10:01 AM
94 dodge caravan vents not working ksmith4995 Caravan | Voyager 4 05-31-2004 09:37 PM
??? 2nd row vents not working kreilly111 Caravan | Voyager 1 01-23-2004 06:21 PM
