17.3 @ 78.87mph with a zc crx..... why?
Went to the track tonight..... and came up with these poor results....
60" 2.465 330 7.121 1/8 11.053 mph 61.74 1000 14.503 1/4 17.387 mph 78.87 finished 1/4 at redline on 3rd gear. yes, i know..... horrible.... now im not that good of a driver but i can't be that bad..... so now either a masive tune up but first i wanna find out what tranny was installed cause maybe they screwed me over
![]() zc powa short ram intake dc sports header 2.25 Magnaflow exhaust h/r race springs |
that doesn;t sound right really, its a dohc zc with a 5 speed tranny..should be faster.
check out my slip in my signature, its only for 1/8 mile, but it could give you an idea since i have a sohc vtec, with similar horsepower. did you only run one time? |
ya it kinda pisses me off cause i should have been deep into the 16's maybe even into the 15's
oh ya there was a crx si with ihe that ran 16.4 all night
that is brutal what kinda reaction times were you hitting?
im not a good driver either, but just practice and you will get better |
reactions times from .7 to 1.5 but that make no difference in the times you run....
did you finish at redline or rev limit? hitting the rev limiter KILLS your times. also, what rpm are you shifting at and what ECU are you using.. not sure if it helps, but in the 1/8 mile, i was shifting into 3rd about 100 feet from the finish line, shifting at 7400 rpm. DX tranny.
all i know is that i was nearly bouching off the rev limiter in third as i went through the 1/4..... from my times it looks like i loose alot in the later half.... why?
i dunno, it doesnt make sense. the slowest time i ran all night was a 10.5 and i missed 3rd and coasted to the finish line.
maybe your cam timing is off? what rpm are you shifting at and what rpm does it drop to after shifting.. and what mods do you have? |
what rpms? um just past the readline... dont know what exactly.... found a faster slip here..... no mods completely stock
17.285 @79.92
it really should be faster, let me ask you, did you have any speaker boxes or anything like that in the car? anything that would make it heavy?
Shift right before redline, get better tires and have a nice suspension set up. All that plays a big part of improving your times. You're losing power when u pass redline and hit fuel cut off. Launch at 3000-3500. Keep practicing your launch to see where its best at gripping the road.
hey sorry i missed out on tonight, I needed to go drink which I havnt done in months, I'll race next weekend though!...Thats shitty about ur times?? I was running a 17.4 in my car a little while ago
We should really meet up this week so I can check out ur car!
blah |
anyways thats really a horrible time, just practice driving man im sure it will come down alot
2002 Acura TL Type S 1991 Honda Crx Si |
Hmmm... I'd say low 16s to high 15s would be acceptable with your setup. I know that I have to shift at 8200 to stay on the VTEC profile of the B16A and keep power up. Shifting at anything less than 8000 falls off the power curve.
I'd work out your power curve (dyno) and look at where your revs need to be when you drop into the new gear and then practice your shifts until you can hit the "sweet-spot" every time. Bouncing off the rev-limiter is no good - you will lose power due to the cut-out retarding the engine and cutting spark. Take it to redline and if that means another shift then do it and stay on the loud-pedal. Just as a matter of interest, are you using the ZC gearbox? I think it has better ratios on 3rd over the SOHC ones in terms of run-out. I think - I'm not too sure. Cheers |
How fast can you shift? If its taking too long to switch gears then you are dropping out of the power ban during your shift. If you can shift really fast then dont take your foot off the gas..it wont have time to rev if you shift fast enough. Just dont do it very often..its not good for the tranny
Honda...An Army Of One |
