Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 09-12-2011, 03:30 PM
eHowitzer eHowitzer is offline
1996 Camaro 3.8 V6 Spark Plug Change
I have a 1996 Camaro with a 3.8 V6, and I want to pull the plugs, do a compression test, and replace the plugs and the spark plug wires.
The rear 2 plugs on each side seem very difficult to get at.
Does anyone have any advice on how best to get at them and complete the work above?
Old 09-12-2011, 03:50 PM
Tony Silva's Avatar
Tony Silva Tony Silva is offline
Re: 1996 Camaro 3.8 V6 Spark Plug Change
I don't think it is possible to replace them from above due to the brake booster on the drivers side and the A/C unit on the passengers side. I have done many camaro and Firebird tune-ups and have NEVER been able to get the rear plugs from above. If you look at the lower section of the windshield you will see that even the window is in the way from going straight down from above. I have always had to jack up those F body cars and get the plugs from below.
And as for doing a compression test...you will need to use a tester that has some length of hose on it and screw it into the spark plug hole because there isn't enough room to use the type of tester that is simply pushed against the spark plug hole.
Old 12-07-2011, 11:04 PM
izzydjinn's Avatar
izzydjinn izzydjinn is offline
I own a 00 bird, and it is hard but not impossible. as far as the plugs on the pass. side, all of them are easy, the only one that takes me an extra 5 min. is the one close to the fire wall on the driver side.
Is.... peanut butter jelly time, peanut butter jelly time, peanut butter jelly time, peanut butter jelly time.
Having 3.5L spark plugs in a 2.7L engine. Benjamin_2002 Intrepid 1 02-28-2011 05:19 PM
3.8 head changes. help? thunderbirdcoupe89 Thunderbird 2 12-10-2009 11:43 AM
spark plugs freakyfire05 ZX2 2 02-17-2009 11:03 AM
1999 3.8 Spark Plug Thread size Corndog Man Lumina 2 11-24-2008 01:32 PM
1996 Camaro 3.8 Pinging issue Mark Hart Camaro Discussions 4 04-27-2004 09:22 PM
