Old 09-12-2011, 01:25 PM
Danvitt Danvitt is offline
16 bent pushrods
Hello all,
I replaced the heads on a 93 chevy 350 engine. After listening to some bad advice on how to adjust the rocker arms I believe they were over tightened.
The question here is, is it possible for the valves to be over adjusted enough to cause piston to valve contact in a stock motor?
I'm thinking no and that is impossible since the intake valve is opening as the piston is on the downward stroke. At worst I should only have 8 bent push rods. The only possible contact I can think of is the piston coming up as the exhaust valve is moving downward.
I think that the bent push rods are the result of being shoved into over compressed and binding valve springs.
What are your thoughts?
Old 09-12-2011, 05:24 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 16 bent pushrods
Originally Posted by Danvitt View Post
Hello all,
I think your valves hit the piston from rockers adjusted to tight.
Exhaust valve can hit the piston to as you have found out.
Be glad the push rods bent instead of valves.
Replace push rods and do a proper valve adjustment.
Let us know how it goes.
MT
The Following User Says Thank You to MT-2500 For This Useful Post:
Danvitt (09-12-2011)
Old 09-12-2011, 05:44 PM
Thanks for your response. I've done some more checking and unfortunately the results confirm your suspicions. After pulling the push rods and looking at them a little more closely I actually have 8 bent push rods and 8 broken ones (their still intact but broken in 2 places).
The broken ones just so happen to be the exhaust valves. Given the angle that the pistons must have hit the valves I doubt it would be salvageable. To confirm I installed 2 straight but rusted push rods and ran a compression check on two cylinders. The number 1 spot came up to 118 and the number 3 cylinder wouldn't push past 60.
So much for me getting off easy and only having to replace the push rods. I went against my gut and listened to some bad advice to torque it down to 20 ft lbs. There was about a half inch of threads showing above the rocker arms. Which is about a quarter inch more it should have been I think. I will be counting my losses and ordering a crate engine.
Old 09-12-2011, 06:50 PM
777stickman 777stickman is offline
Hope this link will help you next time. And also the advisor!!!
http://www.classiccarauto.com/impala...t_valves.shtml
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 09-13-2011, 11:44 AM
Schurkey Schurkey is offline
Pistons hitting intake or exhaust valves is totally dependent on piston head shape including the valve reliefs, valve size, valve timing, valve opening, etc.
BOTH VALVES ARE OPEN on overlap, and that's when the piston is at or near TDC of the exhaust stroke. If the valves are open enough--because the rocker has been cranked down too far and the valves cannot close--both intake and exhaust valves could be in the way of the piston.
"I" would compression-test and/or leakdown test EVERY CYLINDER. Even then, low compression could be from broken valve springs rather than bent valves...but bent valves are a possibility. BEST case is that the rockers are STILL too tight...
Valves would have to hit the pistons HARD to break pushrods. First Guess: Valve spring coil bind; and/or retainer-to-guide interference.
That'd be correct for certain Pontiac engines having the so-called "bottleneck" rocker studs. There's no "adjustment" per se, the nuts are torqued and lifter preload is assumed to be correct. Requires precision machining of numerous parts.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
stock 1991 4.3L bent a pushrod? 2000izusu C/K 9 07-09-2011 08:13 PM
'94 silverado HD2500 3/4t 4X4 bent frame y13supio Silverado 3 03-05-2010 11:53 AM
Broken/Bent pushrods Immaterial Cherokee 7 01-09-2007 10:27 PM
bent pushrods what's the cause lonelysoleage27 F Series 5 02-26-2006 02:26 PM
Mandrel Bent vs Crush Bent Ricochet Engineering/ Technical 13 12-19-2003 09:54 PM
