Old 09-12-2011, 12:43 AM
Tomb stone Tomb stone is offline
1995 Taurus front hub/bearing replacement...Anyone with experience
How difficult is it? Will the hub/knuckle assembly easily release from the CV shaft once the shaft nut is pulled, or will I need a special puller?? I looks like I’ll have to remove the knuckle and have a new hub pressed in??? I have a press, so are there any special instructions??? Parts??? Tools???
Thanks,
Tom
Old 09-18-2011, 11:26 PM
papoutp papoutp is offline
Re: 1995 Taurus front hub/bearing replacement...Anyone with experience
It's not a difficult job.
To get to the hub, you have to remove the CV shaft. You won't need a puller if you remove the tie rod from the knuckle and the sway bar from the strut.
Old 09-19-2011, 04:18 PM
Did you have a machine shop press the new bearing into the hub?
front bearing - new or junkyard replacement? gijmcd Sonata 5 02-15-2010 07:15 PM
Front Hub bearing replacement 2002 GT mrrdeac Grand Prix 21 10-14-2009 07:58 PM
2003 Envoy ABS Light is on after replacing Front Hub/Bearing Assemblies jcmae Envoy 2 08-24-2008 07:25 PM
96 Achieva Front Hub/Bearing Replacement HanlonsRazor Achieva 2 03-25-2008 01:07 AM
Replacing front hubs/bearings jackdrum Horizon 0 02-24-2004 02:47 PM
