Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 08-24-2008, 04:35 PM
jcmae jcmae is offline
2003 Envoy ABS Light is on after replacing Front Hub/Bearing Assemblies
Is this normal? If so - does it automatically reset or does it need to be manually reset?
What happened was I replaced both front hub assemblies. And now the ABS light is on. I have checked and rechecked the connections and even after a couple of trips around the block the light remains on.
Thanks in advance for any help.
James
Old 08-24-2008, 07:24 PM
Re: 2003 Envoy ABS Light is on after replacing Front Hub/Bearing Assemblies
I found it...a pin on one of the connectors was not making contact.
Old 08-24-2008, 07:25 PM
maxwedge maxwedge is offline
A990 racer
WELCOME TO AF, TIME FOR A SCAN WITH AN ABS FUNCTION SCANNER THIS WILL ALLOW ONE TO COMPARE WHEEL SPEED INPUTS TO PINPOINT THE SUSPECT WHEEL OR AT LEAST READ THE CODES. Had cap locks on and I am not re typing this. LOL
