Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 09-11-2011, 09:08 PM
bronco89 bronco89 is offline
Unhappy 1989 bronco not starting HELP!!
I have a 1989 bronco eddie bauer with the 5.0l v8. its an efi and its not starting while i crank the motor. it has good pressure in the fuel rail and i checked the inertia switch, plus all the relays and it has spark at the plugs. i know ford had a recall on the tfi module which is on the distributor but i dont know if thats the problem.. and i also tried spraying gas in the intake while i had some one crank it for me. still nothing. every once in a while i hear it fire once but it doesnt happen often. what could it be??
Old 09-13-2011, 02:37 AM
cstarz95 cstarz95 is offline
Re: 1989 bronco not starting HELP!!
I had something similar to what you are describing. You can actually get the TFI module on the dist. tested at Autozone etc. That was the culprit with mine. Hope it helps
Old 09-14-2011, 01:57 PM
chamblizi chamblizi is offline
try checking your alternator a bad alternator can litterally keep your engine from starting if you have a clunk
sound as if its trying to start most likely the alternator is bad
2000 Kia Sportage died on fwy. Will Turn over but not start...HELP over_kia Sportage 3 10-16-2010 02:11 AM
'89 K1500 starts cold or hot, not warm karattop General Discussion 0 05-06-2009 10:30 AM
1989 Mirage won't start help plz.... MirageProblems Mirage 2 11-08-2005 01:54 PM
1989 Firebird Not Starting SPAWN125 Camaro Discussions 5 10-27-2004 12:40 PM
1989 Caddy stalled and will not start...Help? msgatorslayer General Discussion 1 01-05-2004 05:14 PM
Tags
302 , bronco , ford , fuel , starting
