Old 09-11-2011, 09:12 AM
Adasm Adasm is offline
Send a message via AIM to Adasm Send a message via MSN to Adasm
98 grand voyager window motor issues
Ok, i've been reading alot of threads on this subject and I just wanted to post my own with the issues i've found with mine: my passenger window wont move anymore, but it'll move maybe about a 1/4 of an inch if i'm lucky then not move at all. I have done thus so far:
driver's side is fine so i swapped the brushes, armature and capacitor from the working side into the passenger side motor and still get the same result. So i've confirmed that the capacitor is fine, the armature is fine and the brushes are fine. What else could cause the motor to not engage? i've multimetered the hell out of this thing and have found power all across the whole assembly? what am I not seeing that can cause this motor to not move? and it's definitely not a stuck regulator because I can manually turn the armature with my fingertips and move the window fully down and back up again. Any ideas???
Old 09-19-2011, 03:08 PM
Re: 98 grand voyager window motor issues
Wow, not even an idea whatsoever?
Old 09-20-2011, 03:35 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Nope. In the half dozen or so power window problems I've worked, I've always changed a window regulator and it's always fixed the problem. Never taken the time to disect it to your degree. Try spraying a little silicone lube into the side window guides.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 09-25-2011, 10:37 AM
Yeah, i know it's a crapshoot trying to dissect it, but it's just a nagging problem as to why it doesn't work. I'm usually okay with just replacing something if it's broken, but i'd love to know exactly why this is not working. But, i'll probably just end up changing it soon enough.
96 grand voyager no air conditioning question proserver Caravan | Voyager 5 08-21-2011 01:45 PM
Window motor replacement 1988 Grand Wagoneer (Cherokee) Dhood Cherokee 0 03-30-2011 10:54 PM
98 Grand Voyager computer-electrical issues-please help jth121 Caravan | Voyager 4 03-17-2008 07:46 PM
95 Grand Voyager Brake Repair Issues 9fourteen Caravan | Voyager 2 07-29-2007 02:24 PM
96 Grand Voyager windows, locks, doors krashking82 Caravan | Voyager 1 03-22-2007 01:14 PM
