Old 09-10-2011, 11:02 PM
MAD King MAD King is offline
Weird Thing with the Turning Signal
Hello community,
I have a weird problem with the turning signal of my 1998 Lumina LS.
Only the left rear one is not working anymore. I replaced the bulb, but still not working.
The relais (flasher) is still clicking, fast like the bulb is gone.
Any idea what this can be?
Thx
Old 09-11-2011, 08:11 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Weird Thing with the Turning Signal
Bad socket or broken ground on that side.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 09-11-2011, 08:14 AM
Blue Bowtie's Avatar
Registered Offender
The other possibility is the signal switch itself. A little time with a voltmeter under the steering column might help isolate the problem.
Old 09-11-2011, 08:48 AM
Would this cause that only one turning signal is not working? I thought if the switch is gone both signal aren't working.
Old 09-11-2011, 11:37 AM
Tech II Tech II is offline
No they are seperate circuits.....but I would be leaning towards the socket.....
Old 09-11-2011, 11:48 AM
I will check the socket first. Thx
Old 09-11-2011, 12:27 PM
Tony Silva's Avatar
Tony Silva Tony Silva is offline
Check for power at the socket, and work your way towards the blinker switch....checking the wire and connections as you go.
Problems with rear brake light and rear turn signal arfabe16 Neon | Plymouth Neon 0 03-08-2011 08:57 PM
04 Saturn Vue - turn signal keeps clicking even when there's no signal on richter343 Vue 4 07-19-2010 07:20 PM
weird thing with the ventilation wawaweewa Maintenance 0 09-22-2006 05:36 PM
Weird thing bout the Murcielago King of the Road Murciélago (Murcielago) 2 10-19-2002 11:39 AM
Hod in the world do you take off the turn signal lights????? cheeba Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 02-20-2002 10:19 AM
