Old 09-10-2011, 02:36 PM
mrubino mrubino is offline
Clock does not turn off! 1997 Blazer
I don't drive the Blazer very often, so it sits a while between excursions. When I go to use it, the (new) battery is dead or almost dead. At night I noticed teh clock and radio stay on! Although I am able to power the radio off, the clock still remains on. Is this an ignition swich problem? Thank you in advance...
Old 09-10-2011, 04:17 PM
old_master's Avatar
Advisor/Moderator
Re: Clock does not turn off! 1997 Blazer
Factory original radio or aftermarket?
You have to know how it works,
to figure out why it doesn't.
Old 09-11-2011, 04:22 AM
It is the stock, factory radio/CD unit. Nothing has been changed on this vehicle, it just started doing this.
Old 09-11-2011, 02:52 PM
old_master's Avatar
Advisor/Moderator
In the instrument panel fuse block, remove the radio fuse. it should be a 10 amp fuse in the #24 position. Make sure the ignition switch is in the OFF position and that the radio and clock are off. If the radio fuse is not in the #24 position, check your owners manual for its location. Post your results.
Old 09-12-2011, 10:24 AM
Well I removed the fuse, clock is definitely off
Old 09-12-2011, 04:20 PM
old_master's Avatar
Advisor/Moderator
There are two fuses labled "RDO": one is for the radio, which will also illuminate the clock, and the circuit only has battery voltage with the ignition in the ACC or RUN positions. The other fuse has battery voltage at all times and it's for the station memories and the clock memory. If you're certain you removed the radio and NOT the memory fuse, the next step is check voltage at the ignition switch.
94 Lincoln Continental: Lights won't turn off TheWampusCat Continental 8 01-12-2014 11:56 AM
86 corolla sr5 clock does not turn off aznboi_2 Corolla/Matrix/Voltz 0 11-20-2008 04:02 PM
93 storm RADIO DOES NOT TURN OFF WHEN KEY IS REMOVED headblock Storm 1 12-29-2007 01:42 PM
4WD does not turn off... rvaccare Rodeo | Passport | MU 3 02-18-2007 07:02 PM
Radio does not turn off. Relation with electrical locks ? Iemke Trans Sport 2 02-21-2005 06:32 PM
