Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 09-09-2011, 08:21 AM
DERBYCITY_CAT DERBYCITY_CAT is offline
Smile Dtc code p0440
Good morning, I've a 2000 Monte Carlo, 3.4 engine with nearly 108K miles. The engine light came on again this morning. Got a code of P0440 which according to scan tool is a malfunction in EVAP system. Thus far, i've replaced the canister purge valve and installed a new fuel cap. I'm noticing a gas odor at rear end of vehicle on driver side after getting out of the vehicle. Could this be a bad vent valve or vapor hose or canister hose? How do you determine if the vent valve is bad or not? I anticipate to inspect the vapor hose and canister hose this weekend. Hopefully, I can find the culprit. Thanks
Old 09-09-2011, 05:52 PM
Tech II Tech II is offline
Re: Dtc code p0440
Could be just about anything, rusted fuel fill pipe, leaking tank or gasket, vent solenoid, any of the lines, canister, etc.
The only surefire way to find a leak is with a smoke machine...
Old 09-10-2011, 01:49 PM
hillre hillre is offline
Re: Dtc code p0440
Thanks.
How to fix an Evaporative Emission Control System Malfunction - OBD II Code P0440?? mtnagel Engineering/ Technical 14 01-17-2008 12:32 PM
OBD-II Code P0440 blahdude Lumina 5 01-23-2004 09:15 PM
engine code p0440 elocmj LeSabre 1 11-06-2003 10:27 PM
Yet another question. Problem code P0440 89accordlxi Jetta/Vento/Bora 2 03-26-2003 02:21 PM
