Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 01-13-2003, 11:41 AM
89accordlxi's Avatar
89accordlxi 89accordlxi is offline
Yet another question. Problem code P0440
My check engine light came on the other day so I took it to a local parts store that can check the code for you. I got a code of P0440. Which turns out to be an Evaporative Emmissions system malfunction.
My question is, what are some of the parts that I should check or replace to fix this problem.
Thanks in advance for any help.
Peace out....
89 Lx-i
K&N filter
custom intake
Accel coil
sport exhaust
white gauges
side markers
headlight conversion
clear bumper signal/fog light conversion
17" ADR with 205/40 khumo tires
Tokico springs and struts
future plans: Headers-high flow cat.-cat back piping.
Recent addition: '90 Teg LS
Old 01-13-2003, 01:50 PM
Deakins's Avatar
Deakins Deakins is offline
Well, you should check all your fuel lines, the purge valve, fuel cap (), the canister, fule filter. Basically your fuel system.
If you have recently cleared your ECU/DTC, a highway drive and a few days usually makes fault codes go away.
The ringing of the division bell, have stopped...
AF User Guidelines
Old 03-26-2003, 02:21 PM
Berticus Berticus is offline
My check engine light cam on last night, when I checked under the hood I saw that the vacuum hose had disconnected from the filter box and was lying on top of the alternator, and there was a hole burnt into it. This morning I explained this to my mechanic and he told me that there was no need to bring the car in, and I could just buy the $4 hose and replace the old one myself. I’ve replaced the hose with the help of a friend, but the check engine light is still on…
My question is should I wait a few days to see if it disappears or should I take it to the dealership and let them charge me a lot of money for a problem so small?
