Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 09-08-2011, 10:27 PM
rutleep rutleep is offline
2007 Tahoe ABS Control Module??
Can anyone tell me if this is a programmable module or not? Specifically, if I can find a used one at a junkyard off the same year/model, can I simply install it and it work as it should? Thanks in advance for any help.
Old 09-08-2011, 11:32 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2007 Tahoe ABS Control Module??
The EBCM will need to be programed.
Old 09-09-2011, 06:33 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
A used ABS computer/module same part no may work without reprograming
But main engine/transmission computr has to be prgraed for your vechical.
And some can not be programed.
What is the problem with your old one?
What is it doing or not doing?
What mileage?
Will dealer warranty it for you?
Any codes no or check ABS/engine lights on?
MT
Old 09-09-2011, 08:52 AM
j cAT j cAT is offline
why do you feel the need to replace this module ? what is the issue ?
these modules that set on top of the ABS brake valve box are most times repairable. also you can get the same module at a scrap yard to replace it. programing is not required ...
these modules need a good solid ground.. about 60-80 amps is needed to get the ABS pump to run on every start up..this is part of the on board testing ..a bad ground will not produce the proper pressure.
the ABS light will come on !
on line repair is available..most times it is the defective relay that was designed to not handle the high current..[designed to fail]...
most repair shops will not screw around and will replace everything ! this will cost alot !
post back what going on give vehicle details as well..
ABS control module problems jlmie Passat 21 03-08-2012 09:35 PM
ABS Traction control Module (HELP) ohio45344 Park Avenue 3 01-03-2011 10:53 AM
Need for a new wiper control module KronVickan Crown Victoria 0 05-07-2009 04:47 PM
2000 m/c ss ignition control module problems ABADTAZ Monte Carlo 1 05-03-2009 03:53 AM
HELP! ABS Control Module going out? dimn Accord/TSX/Accord Hybrid 4 11-08-2003 09:11 AM
