Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 09-08-2011, 07:20 AM
Josef Stocker Josef Stocker is offline
A/C rear tube is leaking. Where to order?
Hi
Since a while I am loosing A/C liquid. The garage found, after a while and using some florescence in the liquid, that the tube going to the rear A/C is leaking (corrosion).
He likes to replace both tubes, the one going and the one on return. Unfortunately this tubes are hard to get in Switzerland. Is there an online store to order these tubes? (Delivery can be made to Florida).
To have the exact part number I need e part book or at least a design/draw from the body parts. Where can I get access on parts-books of Transport 1998?
Thanks, Joseph
Old 09-08-2011, 07:27 AM
brcidd's Avatar
brcidd brcidd is offline
Re: A/C rear tube is leaking. Where to order?
Is it the small 3/8 line leaking right above gas tank filler tube? I've fixed over a dozen of those by using swageloks-- simply cut out the bad spot and splice in the swagelok union.....work great and you need not buy the new tubes --$$$$
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 09-08-2011, 07:59 AM
Originally Posted by brcidd View Post
using swageloks --$$$$
I just check; Swageloks is hard to get in Switzerland, they supply only to industry. No retail shops here.
Old 09-09-2011, 11:14 AM
LMP's Avatar
LMP LMP is offline
Verify www.rockauto.com
they list 2 tube assemblies DELCO#1531000 and 1531001 as "auxiliary a/c components. "
Pictures are available so you can compare ...I just wonder how they can be routed through the assembled vehicle......
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 09-10-2011, 12:29 PM
[quote=I just wonder how they can be routed through the assembled vehicle......[/quote]
Exactly, I checked today how the tubes are fixed/stored but to change them will be a lot of work. I am going to cut the 2 bad pices out (one is from the smaller tube, one from the bigger) and will try to fix it with ? Is it recommended to insert a rubber tube or has it to be metallic? the pressure should be so high, I presume.
Joseph
Old 09-10-2011, 03:02 PM
brcidd's Avatar
you could always insert an inline filter in the bad spot..cut out 2 inches and install one.
'99 GMC Yukon
Old 09-14-2011, 02:15 PM
The inline Filter from AC Delco 15-10413 looks good. Could work on the smaller tube 1cm (3/8 inch) but on the tube going back 1.65 cm where there is another leak, the inline filter is too small. Inline filter goes up to 1/ inch. Have you any other suggestion? The tip with the inline was really good!
Gas tank fill tube leak DavidLang Metro 4 12-02-2010 06:08 PM
Tubes to rear heater core corroded, Options?? '00 GV cheepnis Caravan | Voyager 1 07-15-2010 11:52 AM
Oil Filler Tube Leaking skizot722 LS | MKZ 6 07-31-2007 12:39 PM
Heater Hose tube leaking @ Lower Intake Manifold hernanm4 LHS 0 03-29-2006 12:15 PM
'87 944 Oil fill tube leak Guillaume01 924/944/968 0 10-24-2005 02:25 PM
